Pads are available on Autogeek now.
RUPES BigFoot iBrid Foam Pads, ibrid replacement pads, small ibrid foam pads
I am hoping that they will be stocking the brushes and sanding pads mentioned by Dylan@RUPES in his post on the Autogeek forum 03/5/16.
Quote Originally Posted by Mantilgh View Post
Cool, they should list it in the product description on the AG store site.
What sizes are the sanding disks that are included?
Is the 3mm orbit for sanding?
Dylan@RUPES:
They have that info and I'm sure they can add it to the site. Just as a quick rundown:
Your choice of long or short neck tool for the kit
Carrying bag with custom fit foam insert.
2 battery packs
1 battery charger
1 cord adapter (to run continuous power)
Rotary functional unit
3mm orbit functional unit
12mm orbit functional unit
(6) 40mm coarse blue foam pads
(6) 40mm fine yellow foam pads
(4) 70mm coarse blue foam pads
(4) 70mm fine yellow foam pads
150ml Zephir coarse compound
150ml Keramik fine compound
34mm hook backing plate
50mm hook backing plate
34mm sanding backing plate with integrated foam interface
(10) P2000 35mm PSA sanding discs
(10) P3000 35mm PSA sanding discs
(1) Hard nylon cup brush
(1) Horsehair cup brush
All the items (other than the tools for now) are available as separate replacement/refill pieces. I'm recommending to those who will use this a lot, grab an extra battery pack just in case to have 3 in rotation - especially if you're mobile. UHS, Green, and White foams will also be available separately along with 150ml versions of the corresponding compounds and an additional brush not in the kit (soft nylon).
