Aerosol Trim Spray... any good ones out there?
PAR Detailing
Are there any good aerosol sprays that work well on black honeycomb trim? And ideally wont run in the rain.
Reason I ask is I run into honeycomb black trim semi often and am looking for something to dress this that is easy and works reasonably well.
All input is appretiated.
Jon
stoners trim shine or more shine less time spray or adams .. but they do run alittle in the rain.
Chemical guys Black on Black.used to be called fade2black
Meg's Trim Detailer in spray works great! But will run if you are not careful. It is good enough that you can use very little and/or blotch dry afterwards, helps reduce running when wet.
I'm sure there are a few options from many brands, so others will definitely chime in!
spray dressings never last long. there good for quick shine ups. i have a honeycome grill and thats what i use. couple sprays it looks great easy to reapply every few weeks if needed.
I do the same on my Ford sport trac grill . I use Stoners trim shine it seems to last longer then most .
