After Claying......wipe off or let dry?
Mike
While on "another website" I watched a vid showing the tech not removing the clay lube after claying.
They went straight to the polishing stage, allowing it to dry.
Is this something you recommend?
Thanks.
"Best Practice"
-and it's working backward in the paint polishing process, not working forwards.
-I believe the goal to creating a show car finish is to always be working forward in the process, not backwards.
That means each step you do to the car should take you closer to the goal, not away from the goal.
-I wouldn't do it.
-Heck, it only takes seconds to wipe off the clay lube residue anyways...
Although most vehicles I now detail are not "Show Cars"...
I'm in agreement with the remainder of Mike's above post.
However...
This does not preclude the fact that I may also arrive at my:
Goals'-end...Using different "Best Practices" than others.
But...Despite that fact:
Ridding vehicles' surfaces from spent clay/clay-lube,
(before performing any other detailing-processes)...
is what I've been doing since auto-clay first "hit the market".
Nothing wrong with Mike's post. :dblthumb2:
BTW do you guys always wash after a clay session? My method has been to clay, wipe off the clay lube, then spray more clay lube on the same panel and rewipe. Am I just marring the paint by doing this by rewiping the clay lube that may contain contaminants that came unbonded during the clay process?
Yes, I think he misinterpreted Mike's post. Sometimes people's outlook on things colors what they see in a way that distorts it's real meaning, and causes them to jump to negative conclusions where there was no negative intent at all.
It seems we have something in common. I too, wipe an area as soon as I'm done claying it, with a light touch, and then use more detail spray for a final wipe. If you let it dry, that means more spray is needed and more work. It costs you more to wait until you are done with the whole car before you clean.
I see no problem going directly from clay to polishing, since claying removes the contaminants that could cause marring, and so they are all in the clay or in the slurry left on the car with the lube that if you wipe immediately, are all gone.
I even confess that I go straight to my AIO after that. If I was using just a straight wax, I would consider a prep, like a glaze, which I do for my best work.
I dislike the idea of repeated washings on a project, because the more you wipe, the more you abrade. I believe if the mess is taken off quickly, it is done the most effectively, without a need to rewash. I always wipe off my polish right after I do a section, though. I never let polish dry. If I do, I break out the detail spray.
I do not believe you are causing marring by wiping the slurry up with a soft microfiber towel. Wipe once to get the most of it off, and then spray and wipe again to get the final residue. Works for me. I don't like spending excess time on a car.
Blackthorn,
I really appreciate your input and especially your last sentence really made me feel more comfortable with the method I (we) have been using. Thank you for that.:)
Drew
LOL way to bring the thread back on track. I like to wipe all the clay residue off each panel when I'm finished claying. I figure if gently wiping clay lube off is going to cause additional marring the paint will have already been marred to hell from the actual claying process.
Lol thanks man! It started getting off track at some point. BTW your point about gently wiping vs the actual clay process in regards to marring is a great one and really makes sense.:xyxthumbs:
Any time I clay or use my nanoskin wash mitt, I always follow up with polishing.
