After Water Spraying
goose28
After you spray water on fabric convertible top to remove any loose debris do you let top dry before applying Ragg Topp cleaner?
To use:
Rinse top thoroughly to remove loose contaminants. Spray RaggTopp Cleaner evenly over wet surface and scrub lightly with a soft brush or towel. Allow tough stains to soak for 10 to 20 minutes before scrubbing. Rinse top thoroughly and allow to dry completely before applying protectant.
________________________________________________
Hi.
Get a microfiber towel, non-linting (like a waffle towel), fold it in 4.
Place it over the soft fabric top, gently press it, move the towel to the following section, and follow 'pressing it gentle' until whole top is almost 'dry'. Turn towel sides often, and squeeze when needed.
After doing this, it may be completely dry much faster.
Hope that helps,
Kind Regards.
