AG's "New" Industrial Fireman's Nozzle
IID
Hey all,
I currently have the Adams Fireman's Nozzle:
And I can honestly say that this Adams Fireman's Nozzle,is the BEST vehicle washing nozzle I have ever owned.
But I see that AG is offering their "New" Fireman's Nozzle:
Industrial High Flow Fireman's Nozzle, fire hose nozzle
autogeek_2171_98819965
I'm always looking for new gadget's to play with when washing/detailing vehicles.I'm just curious how this "New" AG FMN will stack-up to the Adams FMN I currently have?
I know there is one way to find out but I just spent some nice $'s on the last AG promo code EXPAND sale (15% off & Free Shipping) and I'm not going to place an order just for this "New" FMN.
Umm,at least I don't think I'm going to :)
I like Adam's shut off valve but man is it overpriced when you can piece the same items on amazon for WAY under their price...and when I say WAY under I mean 30 dollars in savings.
looks like a nice nozzle, it takes some serious water pressure to make these work and the 32 lbs I have at my house won't cut it. I'll get to save some $$ here and won't be buying.
the AG one looks pretty similar to this
It does look similar to AutoGeeks and a few bucks cheaper BUT if I were to try/review one,I'll purchase thru AG and add it to other AG product order's.
Yeah, wouldn't wanna break the forum rules.
But as far as Fire Hose Nozzle's go I think to many online stores sell them for far more than they should be.
I have one of these, but it's difficult to adjust with soapy hands.
I have experience first hand with the new Industrial High Flow Fireman's Nozzle and I can tell you that it kicks butt. :props:
It's built like a tank and has the quality/design of a nozzle costing twice as much. The shut-off handle is made of metal, not plastic, so you can feel confident that it's built to last. The wide range of adjustments from a strong jet of water, to an ultra-fine sprinkle makes it very flexible. :righton:
Chris, it looks just like the one my friend Heath got me for about 10$ (I believe a Nelson). Heres some stuff I posted at L2D awhile back showing the fireman nozzle I got from AG at the time and also the one I received from Heath. I'll give you the quick conclusion I have after all these months. I prefer the spray pattern flexibility of the old one that doesn't have a lever but I never use it anymore because of how easy it is to use the lever on my new nozzle. Keep in mind I don't know that my levered nozzle is the same as the one you show in this thread but it certainly looks the same.
The following info copied from a reply to a thread on L2D about water nozzles.
I thought I'd go take a video to make sure I'm giving an honest assesment of the nozzle I use. I don't know if I ever tried to see how far this thing would force water before. I just know that when I hit the car with it it is very loud and has some kick. I can't imagine needing anything more. In any case I am buying one of Heaths nozzles and will do a side by side at some point after it arrives.
Anyway, here is what this nozzle does with the setup I have. If I had a straight through hose I'm not sure if that makes a difference or not. I mess around with it a little throughout the video aiming it completely straight and parralel with the ground, pointing it up a bit, and lowering and raising pressure a couple times. I think around the 1:33 mark i pull the camera back a bit so you can see its parrallel.
And another reply soon after
Well just a few minutes ago (a couple hours after I shot that video) I happened to check my mail... What did I find? A new Nelson Fire hose Nozzle! So I just went and put together another video to see how it compares to the nozzle I videotaped in the post above.
First I screwed on a quick disconnect so I wont have to worry about screwing it next time. Forgive the fumbling around as I was trying to do it with one hand and hold the camera with the other. Here is a side by side picture and a flow video.
The ones made with a solid anodized aluminum housing, coupled with a stainless steel spray control shaft...are the best of the best. You do get what you pay for with this type of product. Check out Griot's.
I have one of the Industrial FMH. Love it. Love the pull shut off handle. You can get a good flooding pattern with it as well. It ROCKS!!
I've tried many of these nozzles and at great expense since prices seem to be between $28 & $60.
Many of these designs rely on relatively high water pressure 60+ psi and equal water flow. In general from what I've seen, city water can and does meet this requirements quite well however those with dedicated pumps and wells fall short.
Normal household water pressure runs between 25psi and 50psi; low and high. While most of the "Fire Hose" style nozzles work OK at 50psi they very quickly degrade with both pattern and volume at 20psi to 25psi. Combine this with a long length of garden hose and you've further exasperate the problem.
The only "Fire Hose" style nozzle that I've found to work with standard household pressures and supply volume is the model offered by Adams, I have and use this one.
If you tale a quick look at most of the others and compare it to the Adams nozzle it becomes easy to see that their nozzle was designed to work with even the lower household pressure and volumes in mind.
One aspect that has me scratching my head is why anyone feels they need a "Fire Hose" style nozzle to rinse off a car? :dunno: The standard nozzles available at most hardware stores are more than adequate to properly rinse suds and debris from a vehicle and is adjustable to power through just about any of the stubborn areas for about $7.00 compared to $50.00+...
Cool - Yes
Essential - No
Origunally posted by BobbyG:
It is very good and made in the USA!
Cool - Yes
Essential - No
I agree, but perhaps they make for a poor man's pressure washer that doesn't have to be plugged in? I have never used one so I don't know.
Cool - Yes
Essential - No
Hi Bobby, I would have agreed two years ago. I went through (2 or 3) 7$ nozzles that fell apart before spending 20$ on the old style AG fire nozzle. I thought the price was outrageous but on Rons advice I bought and loved it. Realizing 20$ one time was better than the many more dollars I would have continued to spend the other way. Then Heath sent me that Nelson (cost a little over 10$ I believe). You can't beat that!
I like the on and off on the AG nozzle. I have a fireman's nozzle tha I've had for years and I love it. I like the shutoff from Adams because mine has a smaller knob to turn the water on and off.
I agree Corey. I've gone through several cheaper ones and I finally picked up the one I have now. Lifetime warranty was a nice too. Mine is by Bonaire
I went back and looked and at one time I had a Glamor nozzle with the same style shut off as the AG. It was nice but after a little bit it wouldn't turn off all the way. It was all plastic though so it wasn't the best for durability.
:iagree:
I have a fire hose nozzle and I do not like it (available for trade if anyone wants it along with a shut off). I do not need a stream that goes 20+ ft. The splash back of water is the downside.
I like two spray patterns and most dial pattern type sprayer has a "bucket filler" type spray for initial wash off and always a shower spray for rinsing. The twisting back and forth to adjust stream is not convenient.
The downside of the dial a pattern sprayer if you drop them they are goners (start leaking) so expect to buy one every year or so. It is hard to find an adjustable one but found one on amazon that has a life time warranty...so we shall see how that goes.
Hey Corey,
The nozzles I'm referring to are solid brass with internal O-Rings that keep them from leaking. These are so simple last years. The only part that's replaceable are the O-Rings.
Thanks Bobby, the ones bought before I upgraded were the trigger style.
