AIO's
IID
I currently use Pinnacle's XMT360 and DoDo's NFS for my go to AIO's.
I'm looking to see if anyone can recommend another product that has more correcting abilities for production detailing. (DailyDrivers)
What AIO has the most cut properties?
I've used Klasse AIO and it works surprisingly well. I've used it on a couple of cars now and I have to say I'm impressed with it.
I've never tried ANY Klasse product,But I'm confident from the reputation on this forum,it should work well.
I'll give it a try.
Thanks for the response Bobby.
KAIO is a great product but I wouldn't really describe it as having any correction capability.
D151 has pretty good cutting
Yes,I've seen Kevin Brown's post to another thread of mine on the D151.It's very interesting.
The Meg's D151 is only offered in a gallon size but for $29.99 it's definetly priced right.
yes it us but i wouldnt use anything more then a white pad..
The POLY was almost ordered.
I decided to try the Meg's D151.For production detailing D151 made sence. $29.99 a gallon,I had to try.Even if I have to apply a coat of sealant or wax,it's the polishing(cleaning/light correcting) that will save me time. (Time is money)
The D151 is pad aggressiveness sensitive.Heavier correcting details/orange pad,lighter correcting details white/grey pad.
I'll see how the D151 works but will consider the other's next order.
D151 has the better correction ability out all mentioned. I usually top with what ever sealant or wax
Meg d151 with the proper priming and pad pressure works great. I also like fk 215, less cut the 151 but cleans better and the protection lasts longer.
Whats the consistency of 151?
I was thinking of putting it in a optimum hyper polish bottle and use it as a spray!! (That way, pad priming is easier!)
btw I have tried XMT360 without much luck! (The paint in question was already in perfect condition with minor swirls and micro-marring here and there!(factory paint then! Maybe it was harder than what XMT360 could handle!?)
From what I hear from collective sources, is that Hi-Temp HT-69(Paint perfection glaze) and JW Prime:Strong, are under-rated AIOs with quite capable correction abilities!!?
I'd really appreciate some feedback on those!! I'm out in the market for a new AIO (ideal requirements - Good correction ability + good protection!(protection isn't that important though, as I'll be sealing the paint soon after anyway!)
M151 is too thick to spray
I get great results with a white LC flat pads
it is also worth mentioning that you can mix OPT Poli-seal with OPT Polish II to achieve more cut without losing the benefits of the AIO. I can't remember the ratio though. Someone on here will know.
^Thats awesome!! :D
But I have hyper spray polish! I guess I'll try mixing it with XMT360 and see what happens! :D
70/30 70% poly seal 30% polish II
D151 is also gummy. Use some pad conditioner or lube and work it in good. It corrects great, though!
Another worth mentioning, although from another vendor, is Werkstatt Prime Strong. I tried it on a silver M5 quickie for a client with good results.
You all know I love Klasse AIO, but its correcting abilities are nothing compared to other AIOs like D151 or Optimum.
Now I have to chose from D151, poly-seal, JW Prime:Strong and HT-69 paint perfection glaze!!
Its gonna be one tough decision!!:help:
