D&D Auto Detailing said:The purpose of it isnt to remove dust. Its to remove oils from the polish to get the surface ready for sealant. To remove dust, I just rinse the car off with the hose. 50/50 is correct. In a spray bottle on the surface, then wipe off with MF. Will not stain or discolor trim. You can actually use it to clean trim and rubber.
killrwheels@autogeek said:thats right ... alcohol is already water down when sold. Try to use the 70% versus 90%, or you will need more water. And yes it is really done for removing fillers and oils, but will work with dust in a pinch as will most qd'er's.
trhland said:isnt it also for after you polish a panel spray it to remove oils and see if the scraches are really gone and not covered up by the oils
Bubbabuff said:isopropyl alcohol, is this the stuff you buy at the drug store to clean cuts? Or does a body shop supplier have it? Will the bottle say if it is already watered down?
