aluminum rims
HARDCORE DETAILING
Can I use the MOTHERS POWER BALL AND POWER CONE with WOLFGANG METAL WERK ALUMINUM COMPOUND AND THERE FINE POLISH?Can you suggest a sealent also. Thank you.Or maybe can i use my rupes mini polisher?
The Wolfgangs Metal Werks is s topper for protection.
The yellow powerball is for polishing metal and more cut than the red powerball.
Polish first then seal.
I was just in your neighborhood at the Rod Run.Are the rims clear coated or raw?
As 57BornToRun mentioned, you need to confirm the rims are uncoated, bare aluminum.
If you want to use our PowerBall or PowerCone with those 2 polishes, you'll need to clean the tool before using the second, finer, polish.
Use a low speed (less than 300 rpm) on your cordless drill.
Thanks for the heads up
