another clear coat question
StephenK
i got a H2 coming in next week and was wondering how is the clear coat on these?
my first thought was going with OPT spray compound/polish with LC orange pad on PC. then i thought how big is it and may end up using DeWalt 849. is the 849 overkill?
I don't remember the paint being overly soft or hard, but the H2 is a ton of work not only from size, but the height and odd panels. I ended up using the PC with a 4" pad a lot, kind of ironic considering the size of the vehicle.
If the paint is bad, I would correct the bulk of it via rotary and finish with the DA.
thats another way i was thinking of doing it to. right now the customer is debateing between a 1 step or 2 step. and of course it is black
Good luck on a car that big! Even if I just did a 1 step it would probably take me 2 days by the time I washed it, clayed it, taped off everything and polished then sealed it. I can for sure see how 4" pads will come it handy A LOT!
If your experienced with a rotary I would go that route.
I have polished out black vehicles with a 50/50 wool pad with a quality all in one polish with total paint correction and when looked over outside in the direct light, not a swirl to be seen.
With a little practice 50/50 wool pads save alot of time and with perfect results.
Is that purple foam wool or a blended wool?
