Another Polisher
gordster1122
I got the G15 kit couple months ago love it and I was thinking about adding another polisher what polisher do you guys think I was looking at the Flex 3401 ??
Current Polishers
- G15
- Harbor Freight DA
Why do you want something else? Is there a specific task or set of tasks you are trying to hit?
Do you feel like you're not getting enough out of the G15?
It's a disease. I would suggest a Rupes 75 "Mini". It works great to get into spots where the 15 is too big, like bumpers and mirror housings.
Flex PE-14
Was looking at this also never used a rotary before was watching videos on youtube on them they cut defects fast so if I decided to get one use the rotary for cutting and my G15 for finishing ?
With the current polisher you are already good to go for most case. However there are so many case that Rotary can get you through while it's hard for DA type machine. You can continue using DA on most case from cutting to finish or one step procedure. But when heaven call, you will need a Rotary.
Buy Another Polisher ?
Do you think there will be a sale on polishers for black Friday
Before I got my G15 I was looking at the Pink Flex 3401 on here with the extras what would you choose between the 3401 and PE14
The PE-14 is significantly more powerful than its sibling the 3401. If you already own a G15 and after more correction power I can't see any benefit going with a 3401. PE-14 or Rupes MKII would make more sense.
If I went after the Rupes would it be good to get another 15mm for versatility I know the 21mm covers more but I rarely do big vehicles mostly just cars
Are you after more correction than what you currently have or just wanting another toy?
If more correcting power 21MkII hands down. If you just want another polisher for the sake of it then get a 3401 as it behaves completely different to any other polisher out there.
I would say little bit of both be nice to have more correction when needed
Current Polishers
- G15
- Harbor Freight DA
get the flex 3401, and you won't have to worry about any stalling issues if that's a concern. also, buy a GG 3" DA backing plate for your hf da when it's available...
If you're just looking to expand your arsenal you can consider the Griots Garage 3". Its good for those tight spots.
