Another scratch removal thread
Jas123
Hey everyone.
Just getting opinions on the best way to fix this scratch that seems to be down to the primer. You can get a fingernail in it.
I done some searching and a possibility for fixing the scratch was to use spot putty to fill the scratch, then on a foam block with a shop paper towel around it, use paint leveler and remove the excess putty. Then with a artist brush paint the scratch.
The only thing won't the touch up paint be higher than the original paint. Would I use some kind of compound to level it out?
Thanks
I would skip the putty and just build the paint up to the level of the surrounding paint (really just a little above). Then you're going to need to level it out with some really fine sandpaper, and then compound/polish. That's how I would do it.
On that color,it will look worse because of the metallic.when touching up it will look darker.I would sand the whole scratch with 1500 or 2000 melt it down with heat and compound and call it a day.
Silvers and golds are a challenge to touch up. Take some rubbing alcohol and wipe the scratched area. At that moment look at the scratch. Did it disappear? If it did then you need no Color to touch up. You will only need clear coat to repair.
Well it didn't go so well. I did clean it with alcohol and it didn't disappear. So I filled it with touchup paint then used the only compounds I had. Meguiars polish and scratchX 2.0. Probably not the right compounds but it was all that I had. Right beside the scratch there was a spot just a tiny bit lighter. I don't know if someone had tried to get the scratch out before but now its lighter all around the scratch now.
Just like with the replies it does look like its a challenge to repair to look correct. On top of all of that is I'm kinda new to this.
It's really hard to tell from the pic. It looks faded around the scratch now.
Anyway to save it at all?
Thanks for the replies.
You should give these a good look. I think they're pretty good instructions. Make sure you watch both parts of the 2007 Honda Fit video.
[video=youtube_share;jmEhsuO2cKY"]How to Wet Sand Vandalized Car Paint - YouTube[/video]
[video=youtube_share;S2aC_oseMe4"]Best Paint Touch-up Tricks: Mercedes G55 - YouTube[/video]
The paint should be left to cure for at lease a few days before working it. Did it pull the paint back out of it?
The part about it getting cloudy in the surrounding area is a little scary. Hopefully it is just from using the ScratchX which is more abrasive than Ultimate Polish, if that's what you have.
UPDATED 9/2015: Autopia Polish Comparison Chart
I would try just the polish and see if it clears it up. If you see the cloudy area starting to grow more, stop imeadeatly.
If you are doing it by hand, try using a foam wax applicator with the polish. It will be less aggressive than a microfiber towel or applicator.
Did you use hand or machine?
Probably not the best way to touch up but all the paint I had was spray. I puddled it in a cup and used a tooth pick to fill the scratch. Lame I know.
Yes, I'm using Ultimate polish but I'm afraid it will continue to haze or whatever its doing. It really looks like the paint is getting more silver? I may try with a foam applicator.
I done it by hand.
Thanks again for the replies.
Is this car pre owned or are you original owner.The color change is probably from the alcohol swipe,I can't see doing damage by hand.
Pre-owned. I bought it a couple of months ago.
I was thinking the same thing. Surely I'm not taking that much off by hand.
Impossible by hand.maybe you are marring the paint by hand a little.But can see color transformation in pic caused by alcohol or polish leaving you with naked paint as mike p would say.
So some clear would bring the color back?
I dont think it was the alcohol. I put some one a qtip and just wiped the scratch itself and wiped it off and didn't notice any color change.
Put some wax over the scratch and see if it reverts back.
Wax didn't seem to help at all. I have no clue what it could be.
Did you let the wax dry completely before removing.I seem to think it was damaged prior to you owning it,now that your more focused on it your eyes are picking up everything.The second pic looks shallow and burnt.put some water over that spot continuously,then take your finger and go over scratch area.See if you are getting drag over the scratch versus the rest of panel.If you are getting drag then more than likely it's cooked.
Yes I let it dry for about 15 mins. I will do the water test tomorrow.
I agree. I think it was something going on before I did anything to it. There was a small spot of color being lighter. So I really don't know what was going on.
So there's no way of bringing back the color?
I know this is tough without being able to see it in person.
I know exactly what happened,someone heated the paint with a rotary and burned it slightly.The damage was done prior to ownership.maybe you should of used that scratch as a contingency of purchasing the car.should of had them repaint before buying,if it bothers you go back to dealership and see if they have a vendor who deos airbrush work,I've seen it done pretty cool and won't break the bank,keep in mind it's not a 100 percent repair good luck.
Well I had a guy that does detailing and paint repair look at it and he said the clear is coming of. I wouldn't have thought I done enough rubbing with the compounds I used by hand but I guess I did. I didn't rub that much or that hard even.
I asked about possibly air brushing it but he said he didn't do that and didn't really know anybody that did.
I may take it to a couple more shops and see what they have to say.
You would be the first person on this universe to cook clear by hand lol.I would just fix it the right way and move on.
