Any Need For Meguiar's D151?
The Critic
So, is there a real need to have Meguiar's D151 in one's detailing arsenal if one already owns the M105/M205 products?
I understand D151 has more cut than M205, but couldn't you accomplish the same level of cut (or more) if you went over the same area with M205 twice?
I plan to use an LSP such as Duragloss #105 or one of the Collinite products anyway, so the wax protection that D151 leaves behind isn't a big selling point to me.
While I understand that some members like to own a variety of items to try and test out, at least for now, I am trying to limit my collection to the bare essentials.
Thoughts?
The biggest advantage to #151 is simple .... ONE STEP. It's an excellent product for the everyday driver that needs to be done quickly ... in one step.
I have a sample that I bought a while ago, I tried it on our Yukon, a lot say it has the cut of M83 or so.
I liked it enough to try it and it's sat since. I had a learning curve with it but it works good.
It's a good product for a good one step like mentioned.
I see.
Is it possible though, for M205 to deliver the same results as D151 if you worked it for more passes?
Or on the other hand, is it possible to just carry M105 and D151 in your arsenal? I'm trying to keep a "minimal" inventory to keep costs down.
That's a hard one for me.....
D151 is a AIO (All in One), cleaner wax if you will.
D151 is stronger than M205 but inbetween M105 and M205.
It's something you are going to have to try and see if you like it or not. This product is aimed at high volume detail shops (as it is in the Detailer Line) wanting to polish a car and wax it at the same time.
I have used it and liked it but don't have a real need for it for my own use. I use an assortment of products from M09 to M105 and everything in between. I have to with just my own cars. Our Neon has a hard as nails clear coat that the lower numbered products won't touch, on the other hand, our Yukon is easily corrected with a couple, three passes of M80/M09 and waxed after and stays maintained longer. The Neon gets wind on it and it swirls easily.
I usually stick to M105/M205/M80/M09 combos for now until that dries up then I'm going to try the other great lines that AG sells, I'm liking the Pinnacle or Wolfgang products and Menzerna and....and....too many, not enough $$!
If you can get a sampler of D151, check it out, see if you like it (check your PM!)
If you're in a hurry and wanting to clay and use a cleaner wax and be done then it's your cup of tea. It's a good product, I just don't reach for my sampler.....
Here's my article on using D151 on MOL
2000 GMC Yukon D151/M16.....
I see.
You may get similar results with the #205, but when you're satisfied with the finish, you're going to have to add a wax/sealant. With #151 you don't need to add a wax/sealant.
On the other hand, if you were using #105 to really clear the paint, there's nothing better than #205 to give you that perfect, deep result. In that case, #151 would not do as nice of a job. But still, a wax/sealant will need to be added on top of the #205.
Motto: More work usually brings in better results, ie. #105 - #205 - wax/sealant. BUT, it takes a lot more time and you should charge accordingly unless it's your own baby you're working on.
i went ahead and got a 32oz sampler
:laughing: :props:
I think it is worth it to have an AIO polish in your arsenal, for maintenance polishing like after winter or spot polishing the scratches caused by friends leaning on the car (then wiping the spot they leaned on with their shirt saying "Oh sorry, I'll clean it" :doh:) I love these types of polishes! My $0.02
I bought 3 bottles of XMT 360 (one BOGO) and am trading for a sample of Poorboy's Polish with Sealant with another member here. Anyone want to trade for a couple oz. of XMT 360 so I can try D151 too?
Good points, everyone. Sounds like a 32 oz sampler of D151 is the way to go. I wonder who sells D151 samples?
The only place that sales Meguair's samples is ADS, Auto Detailing Solutions.
The sample is a good deal. It is a bit pricey, but come in a "ketchup" bottle and don't need to be transferred. I only do my family cars, so buying the "detailer" size gallon isn't really needed.
Jenn
Just ordered a gallon of D151. Man, this is going to last me a long time.
D151 is a one step product that is rotary-compatible and comes conveniently in a gallon jug. Those are the reasons for D151. It is not the ideal product for the enthusiast who desires from detailing products the extra cutting power for absolute correction, the fine jeweling ability for ultra smooth paint, and the deep gloss offered by high-end waxes.
If fine polishing the paint to perfection and applying layers of waxes for that ultra-deep gloss is too much work for you, and you would like to use something such as the D151, then detailing is not really the type of hobby for you!
Use the M105/205 or SIP/PO85RD with the rotary.
