DFB
- Aug 12, 2019
- 5,082
- 3,361
I tried to utilize the two bucket method but found it cumbersome and frankly pointless for my particular needs. In reality, I do actually use two buckets, just in a different way.
Bucket 1 (in red) is for wheels. I fill this bucket with water and a usually a slightly alkaline soap to help with wheel cleaning (I rarely need or use a wheel cleaner on my personal cars.) I then add my brushes and tools. Despite rinsing the tools with my pressure washer as I go, the bucket does help with releasing contamination from them into the water.
Bucket 2 is for washing. I fill with water and then add a small amount of my chosen soap to the wash pad. The same soap is then added to my foam cannon.
I then pre-rinse with water, apply the foam and complete the contact wash. Between panels, I rinse the wash pad in the bucket, and because the soap is mostly on the car, I don't need to that second (or third) bucket with a soap solution.
The contact wash in abbreviated terms -
- One bucket filled with water and one wash pad with soap directly applied
- Rinse the vehicle
- Apply the foam
- Contact wash, the wash pad rinsed in the bucket between sections
- Rinse
This method then differs if I'm dealing with a dirtier vehicle -
- Foam the vehicle from dry and allow to soak. Sometimes I will use a higher pH soap to aid this process
- Rinse
- Re-foam the vehicle
- Rinse
- Rinse the vehicle
- Apply the foam
- Rinse
- Rinse
- Rinse
