Id get the 2 hose model which should eliminate or reduce that. There are mixed reviews on Amazon. Thanks for your feedback!I never had really good luck with portable ac. We had about 3 in the house one summer and none of them really worked. I hated that the tank that holds the water was so small, had to empty it every 3 hours... so in the summer nights I would wake up sweating. But that was about 5 years ago, I'm sure portable ac has improved.
Im going to have to check that out. Thanks much!I have used one in the past...13000 think. It took forever to cool the garage by only about 10 degrees and that wasnt in the heat of the day. I opted to install the Mitsubishi ductless unit. My garage window faces the street so no go on the window unit. The ductless unit installed over the walk in door. I did add insulation over the garage in the attic. I still need to insulate the doors before summer hits. Bottom line, the ductless unit was worth every penny.
I have 1 window.
*******************I plan to install a couple low profile ceiling fans in the garage this year. May have to follow suit with the a/c if they don't get the job done.
Unfortunately the window is on the front of the house. Mrs. OT wont go for that.Is it big enough to put a window unit in? I've got a window unit for my garage that works awesome, and it's a lot easier to set up than a portable unit would be. I can get it downright cold in there during the summer!
This is the way to go . Cost a few bucks but it's well worth the money just remember were not as young as we used to be .
Sanyo 12KLS71 Ductless Mini-Split Wall-Mount Low Ambient Air Conditioner-1
Just tucked this thread away for future reference. I found this past summer that while I could tolerate the heat as long as I consumed a few gallons of water, products do some really strange stuff under high humidity.
This may seal the deal!
