Anything better than Leatherique?
Rez90
Looking to restore the leather in all of my cars. I'm no expert but i have read that leatherique does more than the average leather cleaner.
Any other suggestions other than this product?
Thanks.
3 cars.
2010 Jeep SRT8
2010 X5M
2009 GTR
and a friends 2009 M3.
What's the procedure with Leatherique? easy? difficult? I heard something about a plastic bag over the seats?
I never put on a plastic bag on my seats , I wash the seats with a dilutes APC first , then I apply a good coat of Rejuvenatory Oil but I put it on on a real hot day & let it work I just put on some more products after 3-4 hours to let it soak more then dry it with a clean cloth then apply Prestine Clean with a mf sponge then dry it with a clean cloth .
I have an 05 SE R Altima & I maintain my mother s 2010 CTS Cadillac .
Great results , sorry no pix .
There s a great How To from Detailing Image I guess . Can t find it real quick , will check it out & post it if you want it .
Get the 1 Gallon Combo with lots of cars like you have buddy .
I like LeatherMasters products.
Not saying they're "better" than Leatherique...
With one exception...(IMHO): In the procedure-arena.
Swissvax also makes outstanding leather products...on the same or maybe better than Leatherique. Off the charts expensive though and not worth it to me.
Best leather cleaner I have used is 1z deep plastic cleaner and the followed by Sonax leather foam.
Easy. Rub on Rejuvenator. Let it do its job for 18-24hrs or however long you want. Clean with Pristine Clean and a MF towel.
I use garbage/plastic bags because it creates a steam room effect and helps open the pores of the leather. Plus, I like to do the leather in the beginning of a detail so the bags allows me to get in/out of the vehicle without sitting on all the stuff. :dblthumb2:
Best ive used is Meguiars D181 Leather Cleaner
Here a 10 year old never cleaned 50/50 I did earlier this year with it.
Its all depends what you want from a product. leatherigue its not a monthy cleaning product .You must leave it 24-30 hours to fully dry and then clean it with prestige oil ..
It can leave a very clean surface and make the leather soft Also make better the appearance of the cracking ..
other products can clean very well .such as 1z ,meguairs ,autoglym is very good,zaino and many others
True the full Leatherique system is not a monthly thing. But the Leatherique Pristine Clean by itself is. It's a phenomenal AIO cleaner and conditioner. I probably buy Pristine Clean 5:1 over the Rejuvinator Oil
I would be careful with the 1Z product (a very nice interior cleaner but not for leather) because it is an APC (pH ≈ 11) and if not carefully removed after cleaning, it can cause longterm ill effects.
Sonax is a nice product. It is in a foam presentation, which is the preferred one for leather cleaning products.
As above, this is an APC (pH ≈ 12) and hence it has the problems stated above.
Look into products from companies like LTT, Dr. Leather or Leather Master - much more appropriate in my opinion.
As for Leatherique, it is a very nice combo but there are several points one should not overlook, especially on coated leathers. Here's something Todd Helme wrote some time ago about it at Autopia Forums:
Mark,
The answer is yes/no/maybe...
Starting with no... If the pigmented coated (painted/protected) is brand new then it is likely that none of the Leatherqiue will penetrate the finish...
Yes... The pigmented coating will develop microscopic tears and pores over time. The constant flexing of surface will accelerate this wear, which does expose the leather hide underneath... Also holes in the leather, such as near the stitching, provide a direct path to the hide underneath.
Maybe... It really depends on the age and condition of your leather as to whether leatherique is going to offer any benefit. If the car is lightly used, sits in a garage, and is less then a year old, leatherique will offer little benefit.
On the flip side, if your car's leather experiences heavy traffic, temperature extremes, and daily the leatherique treatment will work extremely well.
1z deep plastic cleaner is a leather cleaner I've been using for a very long time and never a problem so not sure where your getting this from. For none treated leather I use Leather Masters. "As with any product you should always do a test spot"
