Anything I can do.....
wytstang
To help with foging?? Man for the past few days as I'm leaving work my windsheild fogs up something fierce. I either have to wait 10+ minutes for it to clear up or try using a mf towel and wipe it off wich really doesn't work. So is there anything out there to help stop it or reduce it?
Yeah, let one of those bunnies loose on the windows! hehehehehehehe :p
Doesn't Rain-X make a window treatment for fog as well?
I just turn A/C on windshield. And keep on, maybe low setting. Make sure it is not just air, make sure it is A/C. Then ajust the temperature.
what kind of car do you have my durango did that last winter and it was my heater core/evaporizer going bad and eventually i had no heat at all... might want to check it out.
You mean defrost? because that's what I've been using, and yes FN rainx makes one but I was hoping someone could tell me if it worth squat...
It is called fog-x. I bought it but never used it. A lot of help, I know...
A/C always clears the front windshield the fastest.
caused my windows to fog up worse..
Flyboy FogX cause it to fog up worse or defrost??
At least you tried :p
caused it to fog up worse. it was damn near impossible to remove as well. i ended up cleaning it off with windex or something because it was just crap. i love rain-x on the outside of the windows, but their products don't seem to work well inside. maybe it was just me though
Guess I will be giving the fog x to my husband - hee hee.
do you park in a garage? i noticed when i par outside, my windows fog up but since im parking under a covering now, i get nothing!
I garage mine, but only 3 of ours fit in there....
Mine fogs when you like go in a movie or somewhere for a while and it is cold and you jump in and blast the heat. It is insta fog, in every vehicle I have ever driven.
In South Florida when it get's a little cool, but maybe a little humid out or there was rain or weather that made the air real moist, my glass insides fogs up like a sonfab!tch, not only my suv but our other 5 vehicles as well. I can wipe witha towel and the fog just goes right back immedietly, only thing that works for me is to use the setting on my a/c that will blow through the vents near the base of the windshield.
Nope apartment and hopefully we close on a Townhome with............no garage :mad:
I found less fog in a car when I clean my windshield inside every two weeks. DP glass cleaner coupled with Cobra WW glass towel really rocks!:righton:
