:iagree:This is the best applicator in my opinion for wheels. The small size works great for tight areas.I've used makeup remover pads that my wife had. It worked well. I liked them because they were small and could get into the corners well. It was super easy to apply and I've done OC on a bunch of wheels. It takes such little product and is an easy sell especailly to owners of BMWs that it makes it worth it.
Does everyone take the wheels off or do you apply OC with the wheels still mounted? I want to do it to my car (also a BMW), but don't have jack stands, torque wrench or floor jack besides the cheap one that comes with the car. Of course, I can always get them but wanted to see what everyone else does.
In your experience, what kind of applicator works best for putting Opti-Coat on wheels? Do you use the same one you would use on the rest of the vehicle? Anybody tried the Wolfgang foam pockets--or maybe cheap 1" wide foam brushes from a hardware store?
Removing the wheel is the best way to both prep and apply the coating. This allows you to position the wheel in any fashion deemed necessary in order to fully clean and prep the surface to be coated.
I like laying the wheel flat and at waist height. This allows me to get real close and move around the wheel to ensure I've gotten everything and not missed anything..
If I can I do!rops:
Thanks guys. I've been cleaning the wheels every weekend to get rid of brake dust so it looks like I'll be removing the wheels to apply OC and plan on setting aside some foam applicators that I normally use for the body. Time to shop for some more tools
I just did this the other day. Removing the wheels really is the best option. Ive used the the cotton make-up pads and find the lint all over for me and keep falling apart. I get the applicator that comes with the Opti Coat and cut in into quarters or thirds (or similar foam apllicator).
Not to thread hijack, but I'd like to know rasky's process for polishing those wheels. Mine need it but I don't know if I should do it by hand or what.
These are aluminum clear coated wheels. I used the mini powerball with megs 105 and it wasn't touching the swirls. It's also hard to get in the little spaces with the powerball. I gave up lol
Did you try the cone, it will get you into tighter areas.
