Frugle
- Oct 18, 2006
- 82
Hello all,
I've been spending everyweekend detailing our 4 cars 1 at a time, So, I have obviously been researched ways to speed up the process.
I've read a lot of people's post that says they are applying their wax with a PC.
Sooo.. I order 2 LC black pads with the expectation of saving time and wax because supposedly the PC can apply it so thin.
This perticular LSP is supposed to be applied very thin, so you don't need a whole lot to wax a normal car. Becasue this wax is expensive, I really wanted to concerve as much wax as possible.
I applied the wax to the pad the way I do polish to a pad... either a nickel sized dot in the center, or a ring around the outside.
Now I have to say, I was utterly dissapointed. NOTHING worked the way it should. the LC black pad is an inch think of foam, so it ate all the wax that I had partitioned to do the car, but never got to the primed state.
I started off with the PC at 4, going fairly slow, with no pressure, trying to watch to see where the wax was going. Being that I had applied the wax as a dot in the center, each pass in one direction was only yeilding about 1 inch of wax applied.
Then I bumped the speed up to 6, and noticed a difference in the evenness at which it was applied... but it still sucked.
Plus, it took at least twice as long to apply it than it would If I had used a normal applicator pad.
So my question is, what is the proper technique to appling an LSP with a PC? obviously what I did didn't work.
to make it worse, it really didn't even work... I let it dry for however long it needed, and then buffed it out... after I buffed it out, I could run the back of my hand across the paint and feel each lane of wax, meaning it was appling in some areas, but never covered the paint. so there was waxed, and unwaxed areas.
I am just completely dissapointed, and not sure what to do.. at this point I have to worthless black finishing pads.
Thanks!
Thanks!
