AR383 vs Spx3000
TopThatDetail
Ordering my pressure washer on Thursday and would like some input on which would be the better choice? Thanks in Advance
I would go with the AR. Cheaper price, name brand and reputable, has more cleaning power[=PSIxGPM], and the hose reel looks more convenient. Plus you know you can get an attachment for the AR to adapt a foam cannon, and obtain AR parts/accessories easier.
How is it more powerful? SPX3000 is 2030PSI and 1.76GPM
Anyhow, I was in the same dilema for weeks, including those 2 plus the Karcher X K5.540.
I finally went with the SPX because of the most power, the 2 year warranty, and the standard quick connect tips. I've used it already to clean brick pavers with rotary/nozzle attachment and it did great.
Thanks for the info not a ton of reviews on that PW but they were all really good.. Did you buy on amazon or order locally and do you use a foam cannon? I want to make sure it will connect
Thanks for the link and info man I have it all in my cart.. I have the MTM foam cannon not the AG one so not sure if I'll have the same issues
Do you use a foam cannon?? And if so do I need to buy an adapter?
Yes sir, I bought the PW specifically for use with my cannon. I had one similar to the two you were deciding between and it kept falling over with the slightest tug on the hose because of its high center of mass. I ended up giving it to my neighbor and purchasing the Greenworks. I picked up a male 1/4" quick connect coupler from Home Depot and installed it on my foam cannon for easy swapping between the cannon and pressure tips. I prefer my cannon at the end of the wand extension for better reach. That and I'm further from the vehicle and get much less splash back!
Anyone use the Sun Joe with a MTM cannon?
Sent from my HTC6435LVW using Tapatalk
