Aussie Muscle!
My uncle was the spare parts manager at the local Ford dealer for decades. As teen in the early 2000's and a budding Ford man, he would often gift me Ford related stuff. In addition to model cars and Ford merchandise, he brought home the entire Ford range of brochures for me to salivate over, in fact I still have them. I even got taken for a ride in the then brand new FPV GT sedan, think along the lines of an Aussie E39 M5.
He also gave me a copy of the DVD that Ford and FPV dealers would use in their showroom or at car shows.
This was shot at Ford's You Yangs proving ground with V8 Supercars driver John Bowe, who was the brand ambassador and test driver for FPV. I've watched this countless times, viewing it today is such a nostalgia trip for me, the early 2000's were a great time to be a Ford man.
This TV add was cheeky on a couple of levels and displays the rivalry between Ford and Holden at the time, from the customer right through to the senior management. The final sequence with the Holden was a very targeted poke.
Interesting to hear comments on that gearbox. This was well before the word "Tremec" was regarded as a good thing. And that's because the Tremec Holden used in those cars was the truck version of the T56.
When Holden brought the Chevy 5.7 Gen-III V8 to the Commodore in 1999, with it came a new 6-speed gearbox, both a massive selling point against the Ford equivalents which had the ancient 5.0 Windsor V8 and T5 gearbox. While the HSV variants had decent power levels, the basic Holden cars were massively choked down and only made 220 kW / 300 hp, although that was easily eclipsing what Ford could deliver with the Windsor. However, it was a common complaint among owners and especially the press, the "moonshot" gearing of 5th and 6th and the lack of low rev grunt from the LS1 made the cars feel soft. And because of that truck spec T56 Tremec gearbox, the press actually favored the ancient T5 Ford was using. Common complaints were as mentioned in the video, the heavy feel and reluctance to select gears. HSV fitted short shift kits, but that didn't do much at all to improve the feel of what was a gearbox out of its depth. But..................the cars were FAST, and THAT spoke louder than the added finesse Ford brought to the table.
When Ford decided to finally join the six speed club, they took the basic T56 design and renovated it to make it more application specific. It was still a hefty thing to use, but the gearing was better and the shift feel vastly improved. Ford also specified double synchros in all six forward gears to improve shift feel.
From the Ford press release dated Monday, August 2, 2004 -
“Ford and the Premier Automotive group have a distinguished history employing the T56 six speed transmissions, which features on products such as the Mustang Cobra R and the Aston Martin V12 Vanquish.
“Drawing on that experience has helped in providing a transmission that further accentuates the sporting nature of the XR6 Turbo and XR8 while providing outstanding shift quality and performance feel.”
There was one teething issue that got a lot of press at the time.....................
When Ford brought the XR6 Turbo with the new turbo version of the "Barra" engine, the limiting factor at the time was the ancient T5 transmission not being able to handle more than the 240 kW (322 hp) and 450 Nm (332 ft-lb) outputs. This meant there was no FPV version of the XR6 Turbo for the BA series. That changed with the BA MK II update that brought the 6-speed gearbox to market. This allowed FPV to boost the power of the turbo Barra up to 270 kW (362 hp) and 550 Nm (407 ft-lb), which ended up being the most torque of any Australian car up until that point, a title held for many years. This engine went into what was called the F6 Typhoon (sedan) and F6 Tornado (ute).
From the FPV press release dated Thursday, October 7, 2004 -
"Because of the benchmark torque output, the F6 Typhoon features a high-tech twin-plate clutch engineered and supplied by British-based AP Racing. This 240mm clutch system creates more precise power delivery and increased durability for sports driving but also reduces pedal effort, therefore providing a more user-friendly manual gearbox for everyday driving. The F6 Typhoon is the only Australian-built vehicle with a twin-plate clutch."
When the press got hold of the cars, it sparked a PR nightmare for FPV. The journalist test drivers were having issues selecting gears, which they naturally reported on. FPV denied there was an issue, even calling out "abusive" driving techniques from the press. It wasn't until the publication in question displayed the issue with FPV engineers present did FPV discover there was a problem. The issue turned out a 0.50c circlip that was out of spec. This put a dampener on the new model's impact, but FPV easily sorted the issue and the Typhoon went on to be a massive success and cult classic. FPV actually ditched the dual-plate design for the later FG models.
Returning back to Tremec gearboxes, Ford held the edge with their version of the T56, which had more appropriate gearing for both the V8 and inline 6 engines. Ford and Holden would both later change to the newer Tremec TR6060 version with improved shift feel. I think prior to the TR6060, the Tremec name was not a desirable thing when it came to gearboxes. Today, the Tremec name is synonymous with strength and shift feel when it comes to big horsepower performance cars.
I have a vague memory of the "gearbox wars" back then, but, as bad as this sounds, I wasn't interested in manuals back then, and I'm still not interested, at least in the cars I want.
Same, I was never into manuals. There seems to be this rule that car enthusiasts must love manual gearboxes, something I have never subscribed to, even as a teenager. Sure, I have had two manual Ranger's, but that's because they didn't offer an automatic on the base model cab chassis. And yes, my Mustang is a manual, but I only chose that to try something different. Otherwise, a manual has never been on my radar.
Speaking more generally, up till the mid 2000's, if you chose a manual, it was clear you prioritized performance. Most autos were down at least one ratio compared to a manual, the taller gearing and slushy feel sucked the life out an engine. A manual was always quicker and more rewarding to drive.
I think this started to change when the ZF 6-speed came onto the scene, first appearing in the BMW range before spreading around the automotive world. The ZF 6-speed was so far ahead of other torque converter automatics that I think this is where we started to see auto's becoming the faster option. The newer 8-speed ZF took that to a new level, to the point where BMW are using that in their M-cars now instead of the previous SMG and DCT transmissions.
The concept of an auto being faster than a manual only intensified with the spread of DCT, especially the Porche PDK. Personally, I prefer the smoothness in ALL driving situations that a torque converter auto brings.
Deyon, I agree with you about the trunk spoiler, ruins the lines outback, pardon the pun but the hood vents are ok, I mean it's a muscle car and over here, back in the day, ALL the muscle cars had some type of scoop, vent or both
I remember reading about the AWD Monaro, that must be a rare site down there, imagine a S/C'er on THAT
I love all the bright colors too, THAT is true U.S. muscle car right there
The original V2 Monaro design was penned on a napkin at dinner by the now current head of GM design, Australian Mike Simcoe. His stylistic signature is rock solid proportions and clean surface language, and if you look at a lot of the designs he has overseen in recent years, you will notice a similar theme. From memory, he hated the spoiler and that it was only made available to please the sales and marketing department. I strongly suspect he held the same opinion regarding the hood vents. I do agree they look appropriate, but for me, it messes with the clean approach Simcoe was going for.
As for rarity, HSV only made 134 of the Coupe 4, 20 of which went to New Zealand. These sold alongside the RWD GTO and GTS versions, the high price and lower performance meant it wasn't a big success. Because of the addition of the front driveshafts, the exhaust headers had to be altered to fit, which limited the power output to 270 kW (362 hp) compared to the 285 kW and 300 kW versions of the 5.7 LS1, and the 297 kW 6.0 LS2. The Coupe 4 was also 4-speed auto only, the brakes limited to twin piston sliding calipers due to space constraints. So, lower power, heavier, auto-only and price limited the appeal compared to the RWD models.
The Coupe 4's development story......................
Meanwhile, this video was released upon the 2001 release of the Monaro CV6 and CV8, presented by the late Peter Brock.........................
The CV6 was an interesting one, it featuring the old 3.8 Buick V6 in supercharged form. These were auto-only and produced 171 kW (229 hp). The CV6 was quietly dropped shortly after the series 2 update, customers clearly wanted the V8. The CV6 was pretty slow and lacking in refinement, think of it like buying a V6 Mustang instead of the V8 powered GT.
I love those vents
Remember when the Monaros won the Bathurst 24 hour race back in 2003. I know they basically changed the rules so these things could race with 427s in them, and they were actually V8 Supercars underneath. But they did last the full 24 hours without breaking down or crashing.
https://youtu.be/Ys55MocgCJM?si=xYkmYDWTCSvvAkGf
Apparently there's a guy driving around New York City in a VL turbo, the article says it's a VL Commodore but the pictures show a Calais. It's heavily modified of course, why would you ship a standard one over. It makes 850hp running between 30 and 36psi on its Garrett G42 turbo.
I also saw an article, that I can't find anymore, about an FPV Pursuit Ute sold in, I think it was, Houston. I would think that would cause heads to turn.
Aussie abroad: The Holden in New York City - Torquecafe.com
What a SLEEPER
That has to be a blast driving around NYC where the prevailing speed limit in most places is 25 mph!
The fabulous VBH driving the Vaxhual VXR8, which was a rebadged HSV Clubsport R8 for the UK market.
The only Holden I would cross the divide for.......................
This one ticks a lot boxes. Being a 2003, it's before Holden ruined the purity of the original design with the ugly and pointless hood nostrils. But it has the much nicer VY interior update. Impulse Blue wouldn't be my first choice, but it shows more imagination than black and has such a lovely glow to it when clean like this. It also has the blue interior, again far better than black dungeon interiors. And being a CV8-R, it's got those black shadow wheels. Oh, and it's only done 14,909 kms.
Very nice, I like the clean original ones as well. I think it's one of the very few I could go back to Holden for. Love those blue seats as well.
My Impulse Blue SV6 was what tipped me over the edge into this craziness. Two washes into owning it and I discovered all the that the dealer had hidden. Nothing really horrible, but enough that I needed to upskill to fix it.
Love that blue interior!
Sent from my SM-S911U using Tapatalk
  • Like
Reactions: DFB
Holden had a lot fun during that era with interior colours, Monaro especially. In addition to blue posted earlier, depending on model year or if it was a special edition, they also offered black, ivory, orange, yellow, mustard and red. There was also a dark plum purple called Cosmo.
You guys didn't get this interior on the Pontiac GTO, but below is the earlier VT/VX interior, which was VERY 1990's and really dated the car. This was replaced by the VY Commodore interior in early 2003.
That white interior
  • Like
Reactions: DFB
That white interior
That one was only offered on the special edition CV8-R, looked stunning against the charcoal paint.
Wow, that looks fun, like the 60's-70's Mopar palette applied to an interior. So much better than today's any color you want as long as it's black . . . presumably to better match one of the 5+ available grey paint options.
  • Like
Reactions: DFB
