Hi all,
In autogeek university under how to remove scratches there is a procedure to wet sand a scratch then use a rotary backing plate with an adapter on a 7424xp to remove the sanding marks with 4" pads.
Question:
there is a DA backing plate available for 4" pads what would be the difference between the rotary backing plate and the DA backing plate, will either one work for this procedure?
Thanks
yrdln
Question:
Thanks
yrdln
