Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
Automatic Swirl Machine
A new forum member joined and included this picture in his introduction thread,
If you get a chance, click over and give him a warm Autogeek Welcome, he's all the way from Sweden...
Hej det är Björn
At my last Detailing Boot Camp Class I rented a car from Enterprise to teach people how to use the Meguiar's and Optimum Microfiber DA Correction systems and the car I rented was completely swirled out from an automatic brush style car wash like you see above...
Here's the pictures...
Pictures & Comments from May 5th & 6th Detailing Boot Camp
2012 Chevy Impala Demo Car
If you look closely you can see straight line scratches running from front to back, there are actually very few circular swirls and mostly straight scratches.
This is a negative of a cropped out section of the paint surrounding the reflection of the overhead florescent light near the windshield.
Outside Sun Shots
Scratches at the front of the hood....
Scratches at rear of hood...
Again, most of the scratches are running in straight lines...
This is a full size, cropped out section taken from just above my finger in the above picture...
Here's a Negative of the same picture...
Same type of brush scratches all over the car...
Close-up cropped out of the above picture at full resolution...
Big Picture - Take Ownership of The Car Wash Process
Point being, if you want to keep your car free from swirls and scratches you cannot take it to one of these types of car washes. They will scratch the heck out of your car's scratch-sensitive clear coat finish.
Removing the scratches mean compounding or polishing to remove some paint to level the surface. The factory clear layer of paint on a new car averages around 2 mils thick.
The average Post-it Note is 3 mils thick. Find a post-it note and hold it between your fingers and then say to yourself,
And after you do this it will sink in how thin the paint is on your car, (thank you new car manufacturers), and why "YOU" must take ownership of the car washing process. If you would like to see a simple, but effective way to wash your car, check out this thread...
How to wash your car KISS style!
Here's a picture from my how-to book that also makes this point...
Hej det är Björn
Outside Sun Shots
"The clear layer of paint on my car is thinner than this post-it note"
