I am getting back into detailing/correction (hobbyist) after about a 11 break, other than wash, decon/clay, LSP (I had to check my join date). I have a PC that used the old LC flat orange, white, blacks. I didn’t really like those pads and they got trashed in the Florida humidity and heat (distingrated). I have heard good things about Buff and Shine and the LC HDO pads? If I have both a Long Throw and 8" DA would I want the same pad system? I don’t want to have too many options as this is just for my cars and some friends i dont need one of everything just a good system for my 3 cars initially. I never used the LC black pads as i always found i would apply LSP or cleaners like PS21 cleaner by hand. How do the uro-tecs compare, or should I be looking at the HDO?
I have an old PC with 5’ backing plate that rotted out so im in the market to build from scratch. Here is what I am thinking of moving into and I need help with the pads (and really the polisher)
So many questions. Basically if you were going to start over with a PC and 15mm machine what pad set for the hobbyist that works well, wont breakdown, and has good cut and finish? Any particular backing plate, my LC PC backing plate the foam rotted away.
Thanks!
- Get new 5’ Backing plate for the PC
- Do I want the same pads for this as the 15mm and 3 inch PC but in 5’ ?
- Get additional 3’ backing plate for the PC
- Do I want the same pads for this as the 15mm and 8mm PC but in the smaller size?
- Get 15mm throw polisher with 5" backing plate (not sure of the brand but not rupes, maybe adams/torq)
- Get Maguaris 6” MF cutting pad - Do I need this if getting the maroon cutting pad?
- Get Buff Shine 6” Marron cutting pad
- Get Buff Shine 6’ Yellow heavy polish pad
- Get Buff Shine 6’ White Pad - is this pad necessary is it like the LC white or the black?
Thanks!
