Rav777
- Jun 6, 2011
- 506
- (One) Karcher K Series Bayonet Style Pressure Washer Fitting, Brass or plastic works but make sure you get the one with ¼ threads. AG sells the plastic one. Note: If you plan to get the brass connector it is a pain to put in and take out, I had to hammer mine in with a rubber mallet then twist it into shape, so it’s like a permanent fix. The plastic ones should be easier to take in and out. This is from my recent experience.
- (One) male ¼ threaded quick connect coupler
-Your choice of quick disconnect spray patterns, I prefer the 40 degree spray head.
Here is the brass connector:
Here it is attached. You have to hammer this baby in just FYI. Get the plastic one if you plan to take it out often.
Threaded male QC style coupler
I tefloned the Male QC and then tightened it.
And now you have a short gun!! This is my preference so not sure if most of you will like this set up.
And here it is with a foam cannon.
Enjoy!
Enjoy!
