I got a 7.50 off coupon for AutoZone so I'll probably pick the stuff up today.
I'm really tempted to pick up an HF DA buffer.. I just don't know if I'd be able to use it. I mean do you just buff by hand where it's to hard the reach with the buffer? Won't the finish look different where you do it by hand?
heres my thoughts.. not saying im an expert on DA.. but ive seen some lower end tools...
Anything cheaper than a PC DA wont polish the paint...or last...
The way i save time and money is by buying the right tool and high quality tool..so i get the performance required for the job and avoid having to buy another tool when the wrong ones either breaks or underperforms.
Cleaner all in one waxes wont polish your paint...
3 step detailing your car is a long and back breaking job...i e done it by hand many many times...i just bought a flex and waiting fir it to arrive so i can have the tool do the heavy lifting while i can focus on results.
At the very least.... buy 3 step system if doing by hand.
If doing by hand get a prewax..which is fine polish...seal and glaze..bc honestly you wont remove scratches completely without a DA...the seal and glaze will fill in what you cant polish out by hand...
Then finish witg sealant or carnuba wax...if doing the 3 step system DO NOT use cleaner wax....it may remive the seal and glaze and then step 2 is undone with cleaers wax...you want standard NON cleaner wax.
What led me to finally take the plunge on the flex.
Gal recently skimmed the garage trim in 2 areas and skimmed the garage trim paint on a few of her panels...it took me about 45 minutes of shoulder /arm/hand muscle burning effort to remove it with prewax....the whole time i thought..if i only had that flex...this would be a 15 minutes breeze of a process.
A few days later i bought the flex...
