Best all around pads
Dadillac
Member
Foam, microfiber, or wool? I have an assortment of LC foam pads and they are getting a bit tired. I have used wool covers over my pads for nasty work before. I have never used microfiber. So, because I am not a rich man, what would be the best all around pad to use?
Don
I have never used any other type of pads except foam. To be more specific any Lake Country Pad. But the best is the Lake Country Hybrid Pads for my Flex 3401.
I have never used wool or MF Pads as I never see the need to try something different.
If it ain't broke don't fix it! That's my analogy for me.
Sorry for not being much help with the other 2 types of pads.
Foam is best all around hydrotech and ccs pads but meguiars microfiber cutting pads can make easy work out of tougher jobs
b&s 5.5" flat pads and/or the megs thin 5" DA foam discs are solid choices. as mentioned, the mf pads can be used for the heavier correction so it won't hurt to get a few of those as well...
B&S flat and microfibers, Optimum microfibers. Really not much you can't do with either brand.
B&S 5.5" foam is my go to
I also use microfiber and foamed wool, but the flat foam is my favourite
My experience is with LC Hybrids if forced rotation and LC thin with DA.
I currently have the LC 5.5" flat pads. They are getting tired and want to replace them with 6.5's as I am now using the Griot's machine. I have used wool in the past for cutting and it does a great job in short time. But I never used wool for polishing or waxing so not sure how they do. Microfiber is new tech for me. Just want one type of pad that will get the best results in the shortest time and least work. That's why I am questioning?
Don
LC Flat and recently B & S Flat. Don't care for all the others, ccs, dimpled etc.
Hi Guys,
I'm pretty much down to nothing (PADS) for my ancient G110, uses 6.5" Velcro, attached. Seems the most popular is LC:
I have:
CG Black Wax, & soon Collinite 456 wax - What LC pad should I consider?
CG V36, V38, Meg M205, soon Menzerna (sf4000), Polishes - What LC pad?
I would assume that a polishing pad, would be acceptable for a Glaze, I don't need a cutting pad.
Also what's the dif between Finishing & Finessing pad
Thanks
Rico
The hybrid pads are the best I have ever used. Have a flex.
Went back and used a ccs pad and was disappointed after making the hybrid my go to pads.
Hi Spewking,
Glad the hybrid pads worked for you:props:
This does not answer or help with my question, so perhaps this just gen. info?
Hi Guys,
I have:
Thanks
Rico
For that machine you might want to try Meguiar's foam discs. Black for the waxes, and yellow for the polishes. Oh, and Burgundy for the v36.
I believe the finessing pad is designed to get the maximum shine out of paint, and finishing might be for sealing/waxing. I could be wrong. They may be terms that are used interchangeably.
My personal preference is the Lake Country Hydrotech line. I love that I don't need as much product, or pressure with them, as they're fairly rigid. They cut well, and finish beautifully.
You may also consider a 5" backing plate, to maximize the performance of your machine.
Lake Country Hydo-Tech Foam Pads, hydrotech polishing pads, pads for water-based polishes, buffing pads
HI DLC95,
My G110 backing plate is 5" diameter, previous pads, were Meg Black & TN, then CG's Hex logic, not a big fan of CG's pads.
How do you know, what waxes, polishes, & glazes are water based? Are all them water-based?
Thanks
Rico
Agree with dlc95--the new Megs THIN pads would be best with the G110. Since less mass to rotate it will make the machine more effective.
HI DLC95,
Thanks
Rico
Ok, good. 5.5" pads will work on a 5" plate.
I do enjoy the green, blue, and red hex logic pads, but it depends on what type of paint, machine and chemical I'm working on.
I prefer the Hydrotech because they work in more situations.
I'm not sure how to tell what's water based other than asking the manufacturer or asking in a new thread here on the forum.
