Best Foam Cannon?
Hi guys,
I have just checked with Polished Bliss and they do not send to my country and therefore I need another place which I can buy it from.
It's like a foam gun but instead of using a garden hose with 45 to 90,psi you use a pressure washer with 1800 to 4000 psi. You end up using much less water, and getting much more foam.
Here is a vid using a 1600 psi pressure washer. The more pressure you have the more foam it makes (I am using a 4000 psi gas powered washer.)
[URL="http://www.youtube.com/watch?v=0S7X0r7FjB0&feature=related] - Snow Foaming The ford focus ST[/URL]
[URL="http://www.youtube.com/watch?v=sa7Ig4rHJ4w&feature=related] - Foam cannon in action 2[/URL]
Yep, its foam is much thicker, its shaving cream!!! Can't wait for it to arrive to try it out!!!
Air compressor+Tornador= P.I.T.A.The pressure washer cannons look like the way-to-go.
Just curious but what actual benefit is there to having a foam gun let alone a foam cannon over the 2 wash bucket lamb skin wash? Other than the coolness of seeing the car completely covered in soap what actual benefit is there?
the whole idea of having soap presoak is to loosen as much dirt/grime as possible using touchless tools. Foam from foam gun runs off very quickly (2 minutes max), where "shaving cream" from foam cannon lasts 5-8 minutes depending on foam mix solution.
I personally hardly ever use 2 bucket method...
So I can understand wanting to pre soap the car to pick up as much dirt as possible before dragging the mitt over the paint. My question now is is there any scientific evidence a thicker foam shot from a pressure washer and foam cannon will do a better job than concentrated suds from say a foam gun.
if autoblissed does not send them to US. then try autobrite directly also in the UK.
the real test would be for how long will that foam remain on your paint surface...with a foam gun it's 2-3 minutes, with a foam cannon it's 5-8 minutes...it's almost as thick as shaving cream, and guess how long will that last???
not sure about autobliss, but polishedbliss does delivers to USA. I ordered one from them about a week ago. Still waiting for it to arrive (takes around 2-3 weeks, depending on custom delays).
