Best Foam Gun Setup
Success!!
Thought I updated my situation here, but guess that was on my Lexus Forums Detail Section. Therefore:
Brought back the Greenworks 2200psi machine after multiple breaker issues and got the next model down (2000psi)
Which was a total breeze to assemble in 10 mins and up and running! Connected my MTM Foam Cannon and played w the different settings to produce its foam. Sorry about the black border pics here , as usual I couldnt upload the actual photos, so had to Screen Shot them.
What I really liked was the 32oz bottle (Using Chemical Guys Honeydew Soap) was able to completely cover my RCF Coupe TWICE w pretty good foam. It really didnt roll off the car too bad despite what the pics depict. Let one coating sit for 5 mins before using the Green Tip to blast it all off. Then used rest of bottle for another coating, and my two super soft Wash Mitts in a bucket of soap to put a really soft touch to the surface. I'm very happy w the setup!
The car already had a nice coat of my favorite Pinnacle Wax (clearly visible in way water beaded up and ran off) BUT the only ##### I have is that the car truly does NOT have a slick feeling to the surface afterward - found by running a microfiber cloth on it. Therefore, back to my Spray Wax to do it again. Thanks to everyone for your support and assistance!
Re: Success!!
Happy that you found your setup that suits your need. We wrote about the kränzle PW and those are a big investment. I have seen one getting the new Sunjoe 9000 series of PW. It has the same specs as a kränzle with 2.0gpm and 1200psi. The downside is that's a no autostop when you don't use the spraygun.
But you have got a nice foam on your car. CG Honeydew snowfoam is a good prewash foam. When AGO get the GG foaming system that could be an interesting foams to test out. When you are applying a new coat of your favorite pinnacle wax. You can foam on your surface prep and get a squeeqe clean paint to apply it on.
Thanks for your update on what you went with Gunny! And hope you be satisfied with the setup.
/Tony
Re: Success!!
Since exchanging the first Greenworks Power Washer due to consistently tripping the breaker (Defective Unit) I picked up their 2000psi one which works awesome!
Just tried using the "Mckees" Soap which I believe worked out much better than the Chemical Guys one.
McKee's 37 Xtreme Foam Formula High Yield Foaming Auto Shampoo- Foamaster gun car wash
This soap actually made a much thicker foam than CG and as I mentioned previously, the car actually felt "Slick" to the touch after using this one.
Right now though, I have to attach the MTM Foam Cannon to the very end of the PW Wand which looks ridiculous, but maneuvering it around is clumsy.
Thinking about getting myself a setup like this to make life easier using this whole new Foaming System of wash (Forget if Non AG links are verboten or not?)
MTM Non-Swiveling Short Sprayer Kit - Obsessed Garage
Also, walking thru this place with drool on my shirt is awesome! ...Atlantic Pressure Washers - Power Washers, Parts and Accessories for Sale
They have everything known to man when it comes to putting things together. Makes me think twice about returning this Greenworks for a step up in the PW World! They totally love your famous Kranzle gear Tony!! :)
**Hey, is it just me or does everything seem to be about "Blackfire" these days?
That Atlantic pressure Washers place looks really cool Gunny and it is not far from your house. I would like to go there myself. I have been using Chemical Guys Honeydew Snow Foam but that McKee's 37 Extreme looks interesting. I might have to try that next.
Many thanks my friend.
Definitely give the McKees a shot. If you're an Amazon Prime Member it's best way to go.
Regarding my Blackfire comment- Is it just me or does there seem to be a massive advertising blitz on their stuff? Each order from AutoGeek I take advantage of the free gifts and even tried their soap (bucket wash) plus soap amplifier too, which is a joke IMHO.
But, it's all trial and tribulations right? ��
Blackfire is owned by PBMG and the products that I have tried so far are pretty good. I have the BF-450 APC, Tire Gel, foam boost, microfiber detergent. The foaming car soap was mediocre. I had better results from Megs Hyper Wash and Chemical Guys Honeydew.
UPDATE TO MY OWN THREAD:
I last reported on the acquisition of that Greenworks PW from Lowes (1800psi) Which worked fine, until the tiny aluminum piece directly above where hose connects broke off! Was well outside the 30 day Return Policy at Lowes, but thankfully know the Store GM well enough. Rather than deal with sending the unit back to Greenworks - he quickly grabbed this new Model of theirs off the shelf and did an outstanding swap for the broken one! 2000 PSI Electric Pressure Washer | Greenworks
For those of you who use Foam Cannons with your PW. PLEASE send me some links to What & Where I can find a whole new "Gun/Trigger" Piece that doesn't have the 1 foot Wand. (Know where Im going with this?) When you attach your Foam Cannon to the Stock Gun it makes it a bit more difficult to control when the whole attachment is almost 2 feet away from where you pull the trigger on the PW Gun. (Make sense?) Im guessing that w a lower end PW like this, one would need a whole new Hose w Quick Connect ends to snap in a shorter Foam Cannon? Trouble is- conveying this clear enough to where someone understands what I mean! ;)
Just buy from Matt at OG. Can get all of your quick connects, pistol grip wand and new 1.1 orifice for your cannon if you don’t already have one. I have the mosmatic along with the PF22 cannon. Much easier to maneuver and better performance.
You can also contact MTM - they also have all the guns/wands/hoses/quick connects as well:
MTM Hydro Products
EDIT: They also have full packages of Hose/Gun/Connects - just call them if you have questions.
Hey Gunny. You might want to try MATCC Foam Cannon, Adams Foam Cannon, Spauto. Or you can customize your own by connecting a series of fittings that eliminates the wand.
Can you take a picture of the fitting on the wand that connect to the spray gun handle?
There is often those fittings to buy separately and then connect to the spray gun handle directly with the foamcannon. That's how I do with the Kärcher fittings. This is if you don't want to put in the money on a new spray gun handle setup.
Appreciate all the great feedback, and come to the conclusion that buying a total kit w Hose, MTM Gear, etc is the way to go. However, I just cannot overcome the pompass attitude he has toward anyone that owns such "cheap, sub standard pressure washers" as he likes to point out on his site. Shot him an email awhile back to simply inquire if he could offer ANY type of Military/Disabled Vet Discount - all he needed to say was "Sorry, I don't" but instead proceded to tell me how hard he's worked to get where he is and that he's not one to give stuff away! He didn't even respond to my last email that included the $400 worth of gear I selected on his site (Cool setup I must add) Totally put me off, therefore I'll be looking elsewhere. Im at both the age, and status to know any such discounts are a "Privilege" offered by a patriotic Co, and NOT a "Right" as some seem to believe. I also always offer to provide folks with my Official VA Rating Docs to prove my issues are real. (Sorry to vent. That dude just rubs me the wrong way, and drones on FOREVER in videos about stuff far removed from the topic at hand) Again, I appreciate you all for the help. Let ya know how it works out.
Semper Fi !!
Yes he is very anti discount. I had a boss similar to him who was all about business plans without any sales/ discounts and would get offended when people would come in and ask if he offered military discount. People I guess think they have to give 20-50% off but that’s not the case. It’s just nice to offer 5-10% discount. If you’ve never been in the military or have family in it you don’t understand the suck we go through.(ie I just got back from 3 days in the field in Germany in 5 inches of snow doing urban operations and reacting to contact.)
Hey Gunny.....haven't seen you on in a while ...I have one of those 'cheap" setups....Sunjoe pressure washer
....works great..
excellent info, I too just bought a cheap Greenworks 1800 (to good of a deal to pass up) and curious about the handle to foam handle connection potential. I'll be following the thread.
That's exactly what I mean man. Like I said above, much of the new generation believe that the "Military Discount" is a "Right" ya know? Its a true "Privilege" offered by a Co or Org that has some type of Patriotism inside them. Like you said, even the 10% or Free Shipping offer is enough to simply make one smile and say thanks! That's all I meant. NO WAY would I expect 50% from a smaller shop like his. AutoGeek offers 10-15% on top of their advertised offers. Im VERY THankful to them. Also, Don sent me a PM saying that Esoteric has the same gear, and I was pleasantly surprised they answered my email in a couple hours yesterday too! Here it is
https://www.esotericcarcare.com/mtm-hydro-spray-gun-foam-cannon-pro-kit/
Thanks for all your help guys - Hey Briarpatch!! Been laying low I guess. Had my 2nd "Coolief" Radio Frequency Ablation done last week so still recoveryig from that. Seriously shocked the pain is so low this time! Been Opiate Free for 19 months now w ZERO desire to return to that junk in my body! Here's a pretty cool explanation of what Coolief is for anyone unfamiliar - cauterizes nerves in my neck.
COOLIEF: A New Procedure to Relieve Joint Pain | Ochsner Health System
Semper Fi, Stay Warm everyone!
Hey There Art !!
Only 6 posts and here you are in one of the good Threads going on Pressure Washer Setups! :)
Happy to have ya along buddy, TONS of great info in here but one can get lost easily with all of these products , terms, opinions, etc! If you ever want some personal favorites on gear you can always shoot me a PM for an assist pal. As a Retired Marine I still love to help others out to my fullest potential - its the First Sergeant in me still. lol. Welcome and enjoy!
OOHRAH !
Awesome that you have found else where to get what you need Gunny. OG is just a place that puts different package together that other shops already has. He is a reseller of some brands. But I totaly understand you wont be getting it from there with the rude response you had.
@Artdnj. If you could upload a picture of the wand fitting to the spray gun handle the male fitting that is. I could help you to see if I can find what fitting it is. There are some different fittings out there but mostly some fits the same brands. If you want I could upload a picture of the different fittings that are used in Sweden. So you can compare it to your and the brands that uses the same fitting.
Did download a picture with different fittings on it. See if any seems to be matchning your PW spray gun handle.
attachment.php
/ Tony
I haven't opened it yet, very cold here. It's a green works gpw 1800 cheapy, looking to get something other than my gas pressure washer to make life easier. I appreciate the help and we'll look at the connection when I get an opportunity
