Best for red/maroon?
08ChevImpala
Is there a wax, polish or sealant that will give better results on a red color car?
I read somewhere that it's best to not use a white color wax for some reason.
Thanks
I actually just got the car recently, so I haven't used a thing on it yet. Doing my research so I get the best results.
Pinnacle Souveran, a true show car wax also called a finishing wax...
How-to Machine Apply Wax using a DA Polisher
Applying Paste Wax By Machine
Souveran Paste Wax can be applied by hand or machine, I personally prefer to apply all my waxes and paint sealants by machine plus the owner Mike has never used a DA Polisher before, only rotary buffers, so I wanted to introduce him to one of the most popular types of machine polishers in the industry.
Using a microfiber glove to hold the wax, you can pop the wax out of the jar and then simply swipe the wax a few times across the face of the foam finishing pad and you're ready to machine wax. Sometimes it helps to lightly heat the outside of the plastic jar with a Hair Blow Dryer as this will loosen the grip crated by surface tension the wax has with the jar.
Here's Mike the owner using a DA Polisher to machine wax his Corvette...
Results....
I could do this all day.... Larry the Cable Guy
:D
I've used Collinite 845 on my wife's dark crimson pearl Toyota with great effect. Of course, I think the product works great on just about any color.
On darker colors I think any suggestion that works well for black will give great results. I can't imagine how nice the products Bob and Mike mentioned will look. They have a great reputation.
Carpro reflect gave my wife's maroon some serious gloss, topped it with Wolfgang sealant spritz
I have found that these expensive carnubas look great but don't last very long at all, especially in the sun!
Thanks a bunch for all the help, but I should've said that the product will be applied by hand.
It's not so much the color that matters, what matters is the condition of the paint. It also matters what you mean by wax; there are different kinds used for different purposes. Do you need an all-in-one, a cleaner wax, or a finishing wax?
Polish is for when the paint needs, um, polishing. If your car's paint is dull or has scratches, you need a polish, and if the paint is real bad, you need a compound. Both go on before a wax or sealant, and neither has any protective qualities.
A sealant is just a man-made version of wax.
Thanks
A layer of wax is only a few mils thick, and regardless of the color it is in the container, it will be virtually invisible once it's on the paint. Some might darken the paint slightly, but that's about it. Some waxes do stain trim.
Meguiar's does make a couple of over-the-counter waxes (I think they are actually sealants), one for black/dark cars, and another for white/light cars. I haven't tried them. While I'm sure they are good products, I have to believe their existence is as much marketing gimmick as anything else. Put another way, I doubt there would be any real detrimental effect by using the black wax on a white car, or vise-versa; I'm sure both will make a car's paint look "good."
I had an 06 LTZ with the 3.9. Unfortunately, I did not have the best luck with that car and traded it in.
Two things I would watch out for is oil consumption and transmission issues. The car would eat over 1 qt every 1000 miles. As for transmission, the car would come out of gear, rev and slam back into gear. It would throw no codes so clearly the dealership felt there was no issue. My fathers 07 LT also performed similarly.
I hope your luck is way better than ours!!
To answer your question, I would recommend Collinite 845, as someone else has above.
Did you end up getting that kit I PMed you about?
Well, I guess a "thank you" is in order, but I guess the guy that owned it before me was really anal with this car. I know that doesn't mean it's less likely to give me issues. We'll see.
No, I haven't pulled the trigger on anything yet, although that kit looks like a nice deal. Thanks
You can't beat it for the price. More money in your pocket means you can invest in other items (DA, microfibers, etc...). Meguiar's makes really good products. Don't discount the ultimate line just because it's over the counter. I think you would be real happy with them. Very user friendly.
Hello 08ChevImpala!
Took note of your username because I've got one too!
Mine is a 2008 3.9 LTZ as well, with the cool "Red-Jewel Tintcoat" color, & the "Neutral" Leather (meaning...light tan lol!).
I'm learning all kinds of good advice/products to use in this forum!
Thank you for your service btw!!
Faron
