By the way, after an arson fire destroyed the facility that housed the #27 Liquid Ebony headquarters, 3M (who else) aquired the rights of, and for, #27 LE. They put it in their line-up as: 3M Perfect-It Foam Polishing Pad Glaze-Dark #05996 or 3M Machine Polish #06064....
I used to use Megs #7, but not so easy to apply/remove, and WG 2.0 is so easy and really pops over Blackfire Wet Diamond.
Jim
In my experience #7 works great adding pop to any finish short term, and while I have topped 26 with 7 I have not tried mixing them, cool idea! :xyxthumbs:
I have done a few show cars and my love combo for them is:
PB Black Hole - for the glaze,
CG Jet Seal 109 - for the sealant
DoDo Juice Red Mist - for the QD
You will have a finish that is impeccable and a durability that will last for a long time!
I've never had the first problem with #7 being hard to use, in fact I would say the complete opposite. When applied thin over a freshly or recenly corrected suface and allowed to dry I find it to be extremely easy to use
They went out of business but they did not produce it.
how are you guys using #7? Are you using it in the "glazing step" and then sealing it? Or are you talking about putting it on top of a wax or sealant? IF so, then you are kind of using it like a QD.
They are about the same.how does this compare to the obsolete Danse glaze?
