I will be using M105 in the near future. From what I have read thus far it dusts a lot and is sometimes hard to remove. What would be the best towel for removing this product. Open to all suggestions.
Hi Keifer, 105 is water soluble and is not hard to remove. It only becomes hard to remove if you let it dry or work it too long than it was intended. Experience with the product will teach you how long you can work it, how it looks like before it dries and how to use it properly. I'm not pretending to be an expert on m105, but i honestly have not had any problem using it, it does dust, but not to an annoying point as some have experienced.
I just use a spray bottle with water, and give the pad a half spray if i still need some more time cutting. So to answer your question, any quality mf polishing towel will do the trick and if it dries on you, it can be easily be removed with the help of some water.
