dpk20x
Member
- Mar 28, 2012
- 748
It wouldn't work on the red part.
Yeah I was just referring to the black part. I have no idea how to restore that pink plastic. You guys saying dlux would work on the pink plastic as well?
All this talk frequently about DLux means it will be in my next AG order. I hear it so frequently from many different users i HAVE to try it. In the meantime, my new favorite for exterior black or grey faded trim pieces is Black Wow Pro. I would love to hit these seat belt buckles with 2, maybe 3 coats. 2 coats on exterior trim pieces last a long time. I would guess it would really last inside on these seat belt pieces. A very thorough cleaning before application is key.
I have no suggestion for turning pink back to red but would want to see BWP on that part too.
Nice work again. I'm sure after a really good cleaning, any trim restorer would give you some decent results.
It will on some plastics, like it did for the OP, not perfect, but better. Trim restorers aren't meant for just black plastic, unless their some sort of die (sp). They do yield better results on black, probably because the color change is more significant on black.
The buckles were thoroughly cleaned and treated with Meguiar's Natural Look Protectant, but I wasn't happy with the look
I believe Solution Finish is unique, because it contains very fine milled carbon in a solvent carrier that allows it to penetrate the plastic
It darkens better than other less permanent trim dressing and better than CarPro DLUX on faded trim
Getting more aggressive, by utilizing the Magic Eraser was also helpful
Dye
Nice, and it seems to be cheaper than Dlux as well. Have you used it on the exterior trim as well? Hows it hold up against that sun?
I have recently applied it to some exterior trim on a couple of vehicles. No info on longevity yet.
Manufacturer claims 4 months for initial application
At the end of the 4 months, the reapplication is supposed to last 5-6 months
Solution Finish is supposed to be launching a top coat that they described as "bulletproof" in a recent podcast
SF does not cover as much trim per mL as DLUX in my opinion
I have not tried DLUX on top of SF yet
The trim pictured in the 'before" shot, is that before cleaning it?
Dlux requires no contact with water for the first 24 hours after application, other wise spots will for if not wiped off. My wife's car sites outside and that's why I haven't used Dlux on it yet. I checked the directions on AG for SF, it doesn't mention anything like this. Does the bottle itself mention anything like that?
If it doesn't spread as far as Dlux, should I waste my time on 1oz? Or go for 12oz?
I would clean with IPA and a small brush. Then use Black Wow which will restore to original.
