Best pad for PO85RD??
93fox
So after having used m205 and ready to polish with PO85RD what would be the best pad to use? as far as brands? im looking at the meguiar's beige foam pad and black foam pad. are these pads suitable for applying PO85RD??? need help here!
I don't use Meguiar's pads, but I've had great success with the gray Lake Country pads. I would have to say, as far as the LC pads go, the gray or the soft green may be the best pads with 85rd.
I like LC black for jeweling with 85RD, but some are recommending using HT crimson.
Gray CCS or Flat. I've used that combo and it has done wonders.
yea ive been looking into ordering some LC pads but i need some for this week and i can only find meguiars pads around here! as far as wetsanding to remove orange peel, what LC pads are suitable for m105 and m205?
Orange and white. What grit are you finishing with? Check out the Surbuff pads with 105.
Lake Country: Either Gray Flat or Crimson HT. Try each one side by side. Depending on the paint you may prefer one over the other.
another question, as far as sanding goes, is there a sanding backing plate for rotary buffers? is it ok to sand with a rotary? im asking because i only have a makita and i have some 3m 3000 trizac disc around but i dont have a backing plate!
Only if you want to re-paint your car.
lol i had qute a time painting that car, i dont feel like repainting it! i was asking this because where i will be buffing the car i dont have a compressor to run my DA with the 3000 discs
Check out ebay or amazon for a pc.
yea i might look around craigslist and ebay and amazon! its a car i just recently painted but i dont consider it finish till its buffed! i will be posting an article soon with pics on how this goes for me!
Good luck Sir:xyxthumbs:
Going to depend on paint hardness but I usually have succes on speed 4 with a Meguiars yellow 8006. No finishing pad has worked for me.
That's called grinding and Ron is right, if you attempt to sand auto paint with a rotary buffer you will sand all the paint off down to bare metal or mess up the paint so badly that you'll have to repaint.
Hand sand or machine sand, I have articles on both in my article list... if it were me I would machine sand as much of the paint as possible, your sanding marks will be more uniform and buff out easier. IF you hand sand, try to get some Nikken Finishing Papers, these use Unigrit Technology and it will help you to avoid tracers and the sanding marks will buff out faster.
What are you sanding?
Surbuff pads are excellent, but personally I would only recommend them is your paint condition is in bad shape, because they are very aggressive.
Its a car i recently painted at school, the thing is that where i am going to be buffing this there is no compressor to use my DA. If there was i would defenetly use that but since i have no other option, i will be doing it all by hand! Im going to remove all the orange peel, what grit do you recommend me to start with?
Cool! :xyxthumbs:
the thing is that where i am going to be buffing this there is no compressor to use my DA. If there was i would definitely use that but since i have no other option, i will be doing it all by hand!
If you can get a DA Polisher you can use it with your Trizact discs.
This article is on dampsanding using Meguiar's Unigrit Discs but all the information would work well with the 3M Trizact discs.
Some guys sand dry, I prefer wet otherwise you need to wear a dust mask so you don't breathe in paint particulates.
Here's everything I have on sanding at this time, first article is on dampsanding. Get a cup of coffee or a cold drink as it's pretty long and thorough article. Also check out the hand sanding article below it a ways.
Wet-Sanding
Damp-Sanding Tools, Tips and Techniques by Mike Phillips <-- This one...
Meguiar's 6" Unigrit Sanding and Finishing Discs
Wet-sanding, Color-sanding & Damp-sanding
The difference between 3M's Hookit and Hookit II Hook-N-Loop Interface Systems
List of Sanding Discs at Autogeek.net
The Rule of Thumb
If it has paint... it gets polished...
RIDS and Feathersanding - A Highly Specialized Technique by Mike Phillips
Wet-sanding - Fresh Paint vs Factory Paint
Basic Hand Sanding Techniques <-- This one...
Removing Orange Peel & Sanding Marks with the Griot's ROP and the Wolfgang Twins
How long will a half sheet of wet/dry sandpaper last before it stops cutting and you need to replace it?
Fight or Flight Method for Gaging Surface Temperature
Can an air-powered DA Sander be used to polish paint?
#1500 is a good normal safe starting point. Some people start at #800 or #1000, kind of depends upon how much material you sprayed, lower grits are going to remove a lot of material fast.
Nikken Finishing Papers have 100% fill over the entire sheet of paper, as well as Unigrit particle size, point is these papers cut faster and more evenly than most automotive grade papers and this allows you to move up one grit level to get the same efficiency while leaving easier to remove sanding marks.
Meguiars Unigrit Sand Papers 6 Pack Kit - Your Choice!
There's other options for getting Nikken Finishing Papers also towards the bottom of this page
All Meguiar's Products
:xyxthumbs:
