Cool! :xyxthumbs:
If you can get a DA Polisher you can use it with your Trizact discs.
This article is on dampsanding using Meguiar's Unigrit Discs but all the information would work well with the 3M Trizact discs.
Some guys sand dry, I prefer wet otherwise you need to wear a dust mask so you don't breathe in paint particulates.
Here's everything I have on sanding at this time, first article is on dampsanding. Get a cup of coffee or a cold drink as it's pretty long and thorough article. Also check out the hand sanding article below it a ways.
Wet-Sanding
Damp-Sanding Tools, Tips and Techniques by Mike Phillips <-- This one...
Meguiar's 6" Unigrit Sanding and Finishing Discs
Wet-sanding, Color-sanding & Damp-sanding
The difference between 3M's Hookit and Hookit II Hook-N-Loop Interface Systems
List of Sanding Discs at Autogeek.net
The Rule of Thumb
If it has paint... it gets polished...
RIDS and Feathersanding - A Highly Specialized Technique by Mike Phillips
Wet-sanding - Fresh Paint vs Factory Paint
Basic Hand Sanding Techniques <-- This one...
Removing Orange Peel & Sanding Marks with the Griot's ROP and the Wolfgang Twins
How long will a half sheet of wet/dry sandpaper last before it stops cutting and you need to replace it?
Fight or Flight Method for Gaging Surface Temperature
Can an air-powered DA Sander be used to polish paint?
#1500 is a good normal safe starting point. Some people start at #800 or #1000, kind of depends upon how much material you sprayed, lower grits are going to remove a lot of material fast.
Nikken Finishing Papers have 100% fill over the entire sheet of paper, as well as Unigrit particle size, point is these papers cut faster and more evenly than most automotive grade papers and this allows you to move up one grit level to get the same efficiency while leaving easier to remove sanding marks.
Meguiars Unigrit Sand Papers 6 Pack Kit - Your Choice!
There's other options for getting Nikken Finishing Papers also towards the bottom of this page
All Meguiar's Products
:xyxthumbs:
