Best tool to apply trim restorer?
WRAPT C5Z06
A foam pad will work in some larger areas, but not thin rubber trim. What can I use for thin rubber trim?
I get a bag of those foam paint brushes from Walmart, they last for two/three times and come in different sizes.
For very small areas, a Q-tip can be used. But for smaller areas, I like using those foam paint brush applicators you can pick up for cheap and can be bought or cut into various shapes and sizes to suit your application.
I have several shoe polish sponge bottle caps. They work well for trim, rubber door and trunk seals, rubber window boots, etc.
Dump the polish, pour in the product, squeeze and go to work.
I just use an old mf towel and my index finger for small areas.
I find that cotton makeup remover pads (the small circular ones) work well.
You can usually buy a pack of 80 for a few dollars or less.
i use these, you can find them at walmart in the shoe section where the laces, etc., are at...
You can always cut a foam applicator pad to most any shape you want with a pair of scissors. No running!
I have been using Ultima Tire & Trim Guard Plus on my plastic trim. It's a bit messy (it's easy to apply too much), but I have found that foam cosmetic or make up sponges work well and make the job much easier.
You can get a bag of these sponges at the local drug store for a couple of bucks. I owe this suggestion to MOL member Bri9801.
I have also sometimes applied trim protector with my latex-gloved fingers.
