Best tool to reach roof of pickup trucks
I'm probably 260 and I can jump up and down on the Werner Work Platform. I know the max weight is around 200 lbs, but the thing doesn't budge. It's pretty sturdy and the legs lock in place with these click arms.
Well maybe.... I'd end up in a heap on the floor with it. I'm 50lbs heavier than the max weight capacity. Wel-Bilt makes one for big folks with a 330lb capacity.
Wel-Bilt| | Work Platforms| Material Handling| | Northern Tool + Equipment Work Platforms |
Thanks for that link. They make an adjustable/expandable one that might be just the ticket.
Wel-Bilt Extension Platform — 300lb. Capacity | Folding Platforms| Northern Tool + Equipment
PS to address an earleir comment, you can't use the truck bed if you have a shell or rigid hinged tonneau cover (assuming you don't want to walk on it).
I'm also pushing 260 and even though the Werner has a 200 limit,I have all the trust in the world in it. It is very well built. I have also started looking at the platform offered by Griots. It has expandable legs going just a little higher then my Werner and has a couple of electrical outlets located on it.
