Make sure you brush it out after it dries. I always brush mine right before I use it. If you don't do this the wool will knot up and it will have a pretty short life.
Dave
because I've only used the mitt once I don't have any experience with it. after using it I rinsed it under the sink & shook it out pretty good. that seem to separate the wool & leave the strands long. almost looking like static electricity spread all the fibers straight out. this should make it easy to brush out. I'll try & brush it before using(while dry) & then I'll try to brush after use(when wet). I'll want to see which way is less damaging & extend the life of it. thanks for the suggestion.
Carlo
