FUNX650
- Dec 1, 2010
- 21,057
- 1
Low quality paint job will be a lot less expensive. Maaco is something i have heard about often but we don't have them here in Canada. They will cut corners and the job will not be as good but you will probably pay less than a 1000$ for that repaint.
The other option is to do it yourself. You will have to spend a lot of time learning how to do everything, paint will cost you probably 200-300$. Other material like plastic sheets, masking tape and the like, an other 100$. So if you are a DIY type of guy, it could be a great project.
Third option, simply fix the problem areas. If you only have clear coat failure on the roof, hood and trunk (most common places since they are hit by the sun a whole lot more), then you could have only those panels worked on (either by yourself or someone else). So it would not be as expensive as re-painting the whole car. Beware that if those panels have failed, the rest of the painjob is probably close to failure too. So if you decide to do it this way, you will have to make sure your paint is protected at all time by a sealant, wax or coating to protect it.
Not sure what year your car is, but a few years back I re-painted most of my Hyundai Accent GSi using color matching paint in spray cans and 2K clearcoat in spray cans. Came out decent. Not as good as a pro could have done but not bad. If you have a high capacity compressor (can't remember the needed specs for painting but think 240V compressor with a huge tank like 60 gallons and up), you could buy or rent a paint gun and that would be a lot better than paint mixed then put in a can. I purchased a gun but my compressor could not put out enough air to drive it for more than a few seconds. So I went with the paint cans instead.
Last option, is to do a roller paint job using rustoleum paint. This is the easiest to do and can do a very good job if you can take the time to do a proper wet sanding job afterwards. It would be a single stage paint with all the inconveniances and advantages that gives. You could do a job like that for less than a 100$, plus the sanding supply.
What exactly do I need to learn to tackle fixing this issue? From what I have read, there is the bare metal, primer, paint and clear coat layers. Is it possible for me to simply wet sand the clear coat away on the affected panels while maintaining the current paint, then using a 2k clear coat from a can to recoat the surface, allowing for that to harden for a few days then wetsand and polish the clear coat? My biggest fear is removing the paint during wet sanding if I tried this. Or, is the paint already damaged from the clear coat failure where I cannot salvage it and need to get a color match and repaint?
Hello everyone, I recently received an older model Honda civic from my parents for my first car. The car itself runs great, but the paint has what I believe to be definite clear coat failure occurring. From what I have read, the best way to fix this is to have the car repainted. I took the car to a body shop to get an estimate and was given a total cost of ~$4,600 to repaint the car. I have attached some pictures of the paint damage at this imgur link.
Is there any hope to fix this issue on my own without paying $4,600 to repaint an older car such as this? What would be the best step for me to take?
Any input is appreciated. Thanks.
This was an awesome thread. I’d love to see one of these paint jobs in person.
Sounds like something fun to do on a test panel to see how it turns out.
Check out baugh auto body on w.broad they are dealer quality way less then your estimate. If you do decide to go macco go to the one on Staples mill they actually put out really nice work...another option for less money would be going over to petersburgYessir
One way to solve the problem of having nice things, is to make more money.
Imgur: The magic of the Internet
I am sorry I disagree with this. To me it doesn't matter how much you make, it is what you do with it.
Well if you don't make enough money, you won't be able to do anything because you won't have any.
