Best way to clean fabric wheel well liner?
mark f
Toyota Venza fabric wheel well liner.
What is the best way to clean? It's a pita trying to get a brush up in there. Maybe I need to try to find a brush w/ small head and a long skinny handle.
This is my first time including a pic - hope it works.
Mark
I would clean with a APC and agitate with a brush. I have a strip of them in my rear wells only and am going to use 303 Fabric Guard to protect it. I'll have to see how well it keeps clean.
I hate these dang things. I have them in the front and rear of my 2011 Charger. All they do is pickup grass and other small bits of debris that are almost impossible to remove. If you find a way to clean this stuff, please post it!
why the hell would they put fabric inside the wheel wells?
Pressure washer - not a bad idea, although it would be a pain in the you-know-what to drag the pressure washer out.
I even poked and prodded the fabric during my last wash. I was hoping that the fabric was just glued onto the top of the wheel well plastic and I could peel it off. But alas, it seems almost sprayed on over the plastic. It also appears to the be the only layer between the wheel and the chassis in some areas - meaning there's no plastic underneith the fabric. This whole fabric on the outside of a car idea seems flawed to me. It's really an eye sore when this stuff is dirty. And it usaully is dirty, no matter what I scrub it with. Anyway, rant over- back to your normally scheduled programming.
One more little rant (I promise, ha-ha!). The farbic they use is very tacky and sticky. Sort of a brillo pad-meets sticky tape-grass magnet. A detailers nightmare when the rest of the car is spotless and you can see dried up grass in your wheel wells. I like a clean car, but I'm not going to remove my wheels and pick all the grass out with tweesers every time I wash my car. Curse you Dodge!!!
More and more auto manufacturers are using that material in the rear wheel wells, and a few in the front also. I have pretty good luck cleaning using a Daytona SpeedMaster brush.
Thanks for letting me know that :props:. I have to do one of those cars next weekend
Let me know how the 303 works out there. I have some and the fabric well liners.
The rear wheel wells of my G37 has that. I imagine it's for sound deadening...maybe a little for road noise, maybe more so to deaden the sound of rocks and other debris getting kicked up by the tires into the well.
I haven't found a really good method to clean those yet. Pressure washer sounds interesting. I don't have one, so can't try it out. If a pressure washer will force the foxtails out of the fabric, then it would be the way to go. What I do is car soap foam and water jet with the garden hose. Cheap microfiber towels (costco), well washed and with a little extra time in the dryer, are nice and grabby and they can pull some, but not all of the crap out of there. The most problematic stuff is grass foxtails. If I wash all the dirt out, and pick out only the most obvious debris by hand, they look pretty clean. Hmmmm, I wonder if a lint brush would work...
I have them as well in the TL, thus far, just ignored them...
Consider me subscribed... :D
Our new Regal has it in the front and rear. A pressure washer works wonders. My method, even though time consuming, spray with Optimum Power Clean @ 3:1, agitate with blue long handle wheel brush from Walmart and soapy water, rinse with pressure washer. This summer I plan to pull each wheel, clean the liners, apply 303 Fabric Guard.
definitely a few other threads on this over the years. i have used power clean at 3:1 or 1:1, agitated with a long reach well brush then high pressure streamed it completely.
I might grab one of those animal-hair lint brushes (the kind that has the peel off tape on the outside) and give it a whirl this weekend.
I'll post after I try the brush and let everyone know if it makes any difference. :xyxthumbs:
APC takes forever to rinse outta these things, IME.
I agree which is why I don't use it every weekend the car gets washed. I do run a brush and soapy water over it but only use APC when it's bad. Thanks for pointing that out! :)
Has anyone found a better way to clean these fabric wheel wells? Is there something that can be applied to make future cleanings easier?
