Better results with 3" mf pad vs 6" mf pad
jvamagic
I wetsanded my car with 1500/2k/3k and went at it with menz fg400. I started with a MICROFIBER ORANGE CUTTING PAD 5.5" and didn't really like the results (had to go over twice or more). This using a PC 7424xp ( I have a dewalt 849 but don't quite trust myself).
http://www.amazon.com/Meguiars-DMC3-Microfiber-Cutting-Disc/dp/B005JPJNMW
I ordered 3" mf cutting pads for the smaller sections and saw a difference from the 5.5" pads. It cuts so much better/faster. Is it because of leverage etc..or because the Meguiar's pads are that much better? The 3" disc don't have much padding so I assume it builds heat quickly which cuts better??? Just trying to figure this out for future reference.
Meguiar's DMC3 3" DA Microfiber Cutting Disc
Chemical Guys - Black Optics Microfiber Orange Cutting Pad (5.5")
I finish with menz 4000 with a white pad and it comes out pretty nice if I may say so myself. I will post photos when I'm done.
I have not tried CG's pads, but the combination of thinner backing and smaller pad will both contribute to additional cut.
For my style, the Meg's MF cut better than B&S (not sure if B&S makes those pads for CG though.
Thanks for your replies....will adjust accordingly.
As a previous poster noted, assuming the power output of the machine is fixed (that you are using the same speed), that power is being distributed over a smaller area (7.1 square inches vs. 23.8) so you are potentially doing ~3 times the work to your smaller area. It's just math. The downside of course is you are only covering 1/3 the area so it will take you longer to get done.
I just stick with Meguiars pads, after all they came out with them for automotive use first.
So if I purchase the 6" Meguiars cutting disc's it will not be much different than when using the 6" chemical guys cutting pad? Have another DIY project and it's my SUV.
:cry:
I really can't speak to the CG pad, but it's just physics that you're going to get better correction with a smaller pad. Why don't you buy the 5" Meg's discs? Or is your backing plate too big?
I have a 5" backing plate. Sounds like I should go with a 5" Meg's disc.
Not trying to be rude, but if you have the balls to wet sand your car, then you can wrangle that Dewalt.
If I was in your shoes and had only those 2 machines. I'd buff with a black tuffbuff wool or scholls spider pad and polish with the PC.
On the Dewalt, concentrate on keeping your pad flat, do your passes on speed 600-800 and you'll be amazed why you didn't grab it sooner!
I have used the CG microfiber discs and tried the meguires and never looked back! The difference for me was night and day.
No offense taken. I see your point. I was going to give it a shot with the Dewalt but being that I have been waiting 15 years to get my Mustang back together after being stolen and completely stripped (minus the power train) I didn't want to risk doing some damage.
If I ever have to wet-sand/buffing, I will give the Dewalt a chance.
Did you wet-sand and buff? Which Meg's compound did you use? Maybe the Menz 400 was not the way to go though it's a great product for correcting other defects.
I am actually restoring a 92 fox body that I completely sanded with 1500, 3000, and 5000. I used meguiars MF correction compound with both pads. The meguiars pads cut through so easily compared to the other MF pads. Also both pads were being used on a Rupes lhr15.
