Bf tps & wet diamond ps applied.
PA DETAILER
well it was warm enough that i wanted to get something on my jeep! after a good wash the paint was in pristine shape. did the baggie test. on to trying out my new BF products! ARE YOU KIDDING ME? the BF TP & SEAL went on like nothing. so easy to use! i went with a mf applicator. by hand. small learning curve here. it really does dissappear into the paint. very unique. did a panel at at time. any residue i wiped off with a mf. amazing! i thought it cant be this easy!! NO DUST, NO STREAKING, NO SMEARING. left behind a amazing even shine. very little product is used. on to the WD POLYMER SPRAY. they work together, as stated by todd. i gave the jeep a final wipedown with a clean mf and the WDPS. again, NO STREAKING OR SMEARING. even on the glass, which it can be used on. nice product. a little different, meaning more watery i noticed than other similar products. the sprayer controls the product just right. again, left a stunning shine on the bright silver.
on to the trim. bumpers/side steps. i wanted to try CC NEW LOOK TRIM GEL. WOW! this product amazed me. applied with a foam applicator. just a few drops and the product sets in the trim. it sets up in a short time. perfect, even look! I LIKE THIS PRODUCT. looking foward to see how it holds up.
if this how the new BF line is, I AM SOLD! looking foward also to see how the BF TP & SEAL holds up.
guess the jeep got WIPLASHED today.
Backfire sure does make some quality products. I have yet to try the TPS but I have the old version of the Polymer Spray and it was my favorite spray sealant. Sounds like I won't be disappointed with the new product!
just curious since im somewhat new here. I have seen people refer to the bag test a few times now. what is the bag test? thanks!!
Here you go...
The Baggie Test - How to inspect for above surface bonded contaminants
After washing and drying your car, the next thing you want to do is to inspect the paint for what we call,
Above Surface Bonded Contaminants
These contaminants can be,
  • Tree Sap Mist
  • Industrial Fallout
  • Overspray Paint
  • Air-borne Dirt and Dust
  • Pollution
  • Road Grime
You can check for above surface bonded contaminants by feeling the horizontal surfaces with your clean, bare hand using your sense of touch to detect what will feel like little bumps or surface texture on the finish. This type of inspection works well and is a good general indicator of above surface bonded contaminants.
The Baggie Test
If you really want to feel what's going on at the surface level of your car's paint or your customer's car's paint, then use "The Baggie Test" when inspecting the paint for above surface bonded contaminants.
Better yet, if you want to share with your customer one of the problems with their car's paint that you're going to correct, let them also do "The Baggie Test" with you. The average car owner doesn't know what detailing clay is, how to use it or the benefits of using detailing clay to clay automotive paint, let alone how to test for above surface bonded contaminants.
Sharing this little tidbit of knowledge with your customer will demonstrate to them that you really know your business and later, after you've finished the job, letting them feel the now smooth and slippery paint will solidify their trust in your expertise. This can help you to retain their business and potentially led to referrals via word-of-mouth advertising.
To do "The Baggie Test", simply use a clean sandwich baggie by placing your hand inside the baggie and then feeling the horizontal surfaces like the hood, roof and trunk lid. The film of plastic acts to intensify the surface texture created by contaminants bonded to the paint making it more dramatic to your sense of touch when you feel the paint through the baggie.
The Baggie Test
You can also inspect the vertical panels and if you detect above surface bonded contaminants on these areas then they should be clayed also. Generally speaking, air-borne contaminants will land and settle on the horizontal surfaces but drift past the vertical panels where they will land on the ground. The main exception to this rule is any air-borne contaminant that is sticky, like Tree Sap Mist or Overspray Paint.
Resources
The 2 primary benefits of using detailing clay to clay paint
Show Car Garage Videos
How detailing clay works and how to use detailing clay to remove above surface bonded contaminants
