Big Blaster Foamer Trigger Sprayer
I like it. I use it with Diablo, apc, and super degreaser. Lots of foam very airy. Just have to control myself sometimes. Reason being, each trigger pull shoots quite a bit of product.
I have 3 of these although I mainly only use 1 for Megs APC for wheel cleaning. Creates quite a lot of foam but, as mentioned, also uses quite a lot of product.
Tried it with Super Degreaser for cleaning my tyres but found I prefer that normally & also save some product.
Have used 1 with Megs APC for over 6 months with no problem.
Don't rinse with clean water or anything.
However I think Wheel Brightener will destroy it so if you are going to use it for that I would spray some clean water through it after every use.
I've heard of WB eating chem-resistant sprayers, even when cleaned after every use, so not sure the foamer will last long at all no matter what you do...
Thanks for the info guys. I think I'll try them out. I'm looking for a high output sprayer and from what you guys are saying, it is.
Oh, one more question. What is the spray pattern like, and can it be adjusted?
The "spray" pattern is pretty much straight & fat, like output from a garden hose. There is no real atomisation.
From memory there is adjustment but it doesn't do much...
