Theraven
- Nov 25, 2012
- 110
30ft chaparral with black hull(gel coat), trying to figure out if parts of it are fried/failing. Here are my observations, there are of areas of the hull that appear to be oxidation, upon a closer look the area is slightly faded with what looks like burned/etched in water spots. They 90% disappear after a polish , in a matter of weeks after the oil evaporates the spots come right back. Do you think these are permanent or superficial? We use imperial&finish material and then 2 coats of collinite paste wax. If the spots can't be removed any ideas on the best Technique/products to keep them hidden longer. One side of the hull is in direct sunlight most of the day.
