hudson1gua
- Aug 17, 2010
- 45
This was the save of the day..somewhat back-breaking.
The overall condition on this paint was horrible, it had such heavy swirls you could barely see the holograms, (there were many more pictures but something jammed my SIM card..thankfully I was able to get these out)..
I decided to go all-out on Mezerna prods. here...After preping the paint with Megs. Red Clay I went as followed.
Using a White LC CCS Constant Pressure Pad, ( I should have dug up an Orange pad,..it would have made my life a bit easier I believe), I put Mezerna and my PC 7424 to the test..
First round using Mezerna IP and 5 section passes of areas 20"x20" on speed No.5,..not much..
Mezerna SIP and the same pad, same speed, 8 section passes covering the same area and a lot of constant pressure and slow movement..Finally worked..
Finally a Green LC Constant Pressure Pad with Mezerna IP and 3 section passes at speed 4 to help level everything out.
Topped it of with a Red LC pad and Mezerna PL..now I am waiting 24 hrs. to apply the final coat..wax.
Let me just add that Mezerna SIP is very nice to work with, no dust and you can work it hard, it takes a while for it to breakdown..just make sure you do break it down, because the down side is it is hell to take off if you work it in half way..Mezerna PL..down right beautiful.
This is how it started and ended on the pics I was also able to save. The results were 100% swirl and hologram free, if something in the picture resembles a swirl it is what's left of a deep scratch.
This is what my pad would end up looking like after the 8 section passes over the 20"x20" area.
