Black tornador/Compressor
rberger
I checked with Tornador and they said to effectively run the unit you need a 20 gallon 2.5 HP compressor with a cfm of 5.5 @ 80PSI.
I am mobile out of a SUV using a Mytee Boss low pressure sprayer.
I see a lot of conflicting info as to what type of compressor to use for the tornador.
What will be optimum for this. Any units you would recommend
For optimal performance, the Tornador Car Cleaning Tool works best with an air compressor that produces 2 CFM or more at 90 psi, the higher CFM the better. One of the many useful features this tool allows you to switch over to just air which helps to blow out any dirt under seats or just those hard to reach areas.
I am considering using the exact same setup tornador black, suv and mytee low pressure sprayer...please tell me what your thoughts are on it (pros and cons).
I guess 10 gallon minimum. WEN has one for $165
I like the Mytee Boss. I would definetely get the deluxe version 5 gallon. I saw a few units that had some new and improved features. Still looking at a few different eco wash products to see which is best. Optimum Meguiars rinse free, etc. I need to find the most compacy yet effective compressor it sounds like 10 gallon min.
