Black wax and Sealant
jimmyb496
Last year, before really diving into the hobby, I did a test between on OTC black wax and Mothers Synwax. the test was on the hood of a black trailblazer ss. So many rock chips it is like gazing into the milky way.
I noticed an immediate difference and the half done with the black wax looked much darker. And it stayed darker for quite a few weeks as I recall. So I thought, there's something there for these daily drivers battered with 150k miles of road scars that have areas really close to repaint time.
Fast forward a couple years and I've cut and polished the truck with Menzerna FG400/SF4000 and applied PL for sealant. I have about 5 or 6 wax options in the shop to choose from for a topper: Souveran Paste, Souveran Liquid, Souveran spray, CG 5050, CG Black, Duragloss Spray, and a couple others I cant think of.
Anyways, here's the question. Does anyone know if a color wax will have the same darkening affect when applied over a sealant?? Logically, I'm thinking the black wax wants to get down into the swirls, tiny rock chips, etc.... almost like a glaze (or maybe exactly like a glaze?). So I'm not sure if the sealant would not allow it to work correctly.
While searching for similar posts, I read a little about Collinite 845 as a wax sealer. Maybe the black wax should go right on the clearcoat and topped with that. But I've already got the PL on, so thats really what I'm directing this question towards.
Thanks all!
Sealant should be applied first if you subscribe to layering. Not quite sure if your asking if the "colored" wax will help cover chips, if so I've never seen it. A test spot is the way to reach any other conclusions.
What black wax are you referring to?
I have CG Black that I'd like to try. I did the test a couple years ago with OTC Turtle wax black.
During testing mentioned in OP, it didn't necessarily cover chips like touch up paint, it did seem to darken them so the "light" color of the chips was less apparent and the hood looked "blacker" on the half that was waxed with the TW black wax. Whereas the Synwax side looked fair, but not as dark. Color wax also made a noticeable difference on the rockers behind the wheels that are littered with rock chips.
My question is, if anyone might have knowledge (maybe have talked to a manufacturer or first hand experience), whether the intended purpose of a black wax (or any color wax) would be negated by applying it over sealant as opposed to applying direct to clearcoat.
I could probably extend the question to include glazes. Are glazes intended to be applied direct to paint, thus their intended purpose (filling swirls, etc) is reduced when applying over a sealant.
Just a FYI. The one thing that I noticed immediately after applying Collinite 915 was that the paint looked a little darker. I know you did not state anything about 915 but you can keep it in your memory bank.
Dave
I haven't talked directly to any manufacturers
of "Black Waxes"; or ever asked them about
these particular products intended purposes.
However:
Just going on your experience where you
stated that an OTC Black Wax had created
a notable darkening (of the ClearCoat), then,
this is what could be concluded...but not
necessarily be true:
If a product, labeled as being a Black Wax, has
the ability to darken cured ClearCoat-paint, it
should also, just as easily: darken an LSP such
as a Sealant.
I personally don't see how a "Black Wax" can,
somehow, actually dye cured ClearCoat-paint
in order to make it appear to be darkened.
How many different hues and tones of
Black car paint, (let alone other car paint
colors), are out there that any of the
Color Waxes will actually "match up with"?
However:
as a Sealant.
I see your point and agree with your logic. Thank you for sharing your thoughts.
I think the color wax is more like applying a tinted wax. As I recall it was very translucent, but you could see the light coloring in it when was on a light applicator or over-spread on chrome trim. Very subtle coloring.
I think I'll try the CG Black over the PL. Maybe I'll do another half n half test for sake of science. Nothing really to lose. I'm getting it ready to sell and trying give her a little extra pretty. I did contemplate a glaze, to help it show better...but, I bought CG Black stuff earlier in the summer and figure I'll try it. So far I've been let down on every CG product I've purchased except their pads... but their marketing is AWESOME, lol.
Dave
Thanks for mentioning it, I will keep it in mind. :xyxthumbs:
