Hi,
Not sure if I'm posting this in the right section but I am getting ready to apply Blackfire Crystal Coat Paint Coating and have a few questions before I start. I plan to wash car, clay, polish, and then wipe with Blackfire Crystal Coat Paint Prep. I am a little nervous because this is the first time I am applying a paint coating and I've read that this product can be a little tricky.
Questions:
1. Is there any particular type of microfiber that I should use to level this product once I apply it? Do the towels have to be thrown away or can they be washed and reused? How can you tell it has been leveled correctly? Do you just wipe until you don't see streaks?
2. If I wanted to remove the product after fully cured could it be removed with say Meguiars Ultimate Polish and 4 to 5 passes with PC DA and polishing foam pad or would I have to use compound? How can you tell you have removed it all?
3. Is there anything that I can use on top of this product? Wax, etc?? What about Quik Detailer and Quik Wax products?
4. How long is the shelf life once the bottle is opened?
I think that's it for now.
Anyway, thanks in advance for any help.
Questions:
