You also may want to try to use BF One Step first before you try the compound, you may be surprised at the results.
Sent from my iPad using Autogeekonline mobile app
Jayfro, that's my plan.
I have Lake Country white and orange flat pads and the Griot's 6" D/A. I figured I' d start with test spots using BF One Step with each pad and check the results.
If I think I want more correction, I'll go to the Megs UC with each pad on test spots followed by the BF OS.
Sound like a good plan guys ? This will be my maiden voyage doing anything like this, so I plan to work into a procedure slowly to avoid more problems than I already have.
