Blackfire: Product Reviewed
swanicyouth
... So I'm off work for the the next two days with not much to do. I decided to change my LSP and try some new products I received via trade on the trade thread. First off, now, I want to talk about Blackfire Gloss Enhancing Polish. This is a chemical polish and paint cleaner that also has a glaze component built into it. This is the first Blackfire paint product I have tried. Quite frankly, for the last few years I've stayed away from AGs house brands. There is no real reason for this, other than me thinking that a dedicated manufacturer would make a better product than I company that manufacturers and retails a lot of products. I'm not sure where I got this idea. Some say Blackfire is kind of expensive, so I want to compare chemical paint cleaner type products based on price:
Wolfgang PPE: $19.99 16oz ($1.25oz)
Pinnacle PCL: $24.99 16oz ($1.56oz)
PB's Pro Polish: $18.99 16oz($1.19oz)
4* PreWax Cleaner:$17.99 16oz ($1.12oz)
Blackfire Gloss Enhancing Polish: $17.99 16oz ($1.12oz)
Chemical Guys Vurtua Bond: $24.99 16oz ($1.56 oz)
1Z Polish Polish Lack-Politur: $17.99 16.9oz ($1.06oz)
Ultima Paint Prep Plus: 25.99 12oz ($2.17oz)
P21S Gloss Enhancing Paint Cleanser: $14.99 11.8oz ($1.27oz)
All these products I would consider somewhat similar, In the sense they all clean paint and are non abrasive. As you can see, the price of the Blackfire cleaner is right on line with all the others at $1.12 an ounce, so it's no more expensive than anything else. I applied this product by hand on a clean washed car using a single microfiber applicator to do the whole car. Previously, the car was recently waxed, and I decided to do this just to change up my LSP. I found BGEP to be a great product. I was easy to use and left the paint slick and wet. It actually did clarify the paint, which was already in excellent condition IMHO. It took me about 2.5 hours to rub down the whole car including bumpers and all external painted surfaces in preparation for Blackfire Wet Diamond Sealant. When I started I found the product to be a bit smeary, but then I realized I was using too much. How much does it take to do a whole car. Unbelievably, it took me about 8/10 of an ounce only to paint clean the whole car by hand:
This is the 2oz bottle the sample came in from the trade, it was mostly full, this is how much was left when I was done:
This is the applicator before I started (brand new):
Applicator after finished:
Blue is from the single stage paint from the letters on my PA license plate:
Some garage reflections left by the paint cleaner, car has no LSP on it:
... It's a great product and I will surely buy a bottle to use again. The only thing it don't understand is how this cleaner also acts like a glaze (it does) and leaves some oils/fillers behind. Since it's designed to use prior to Blackfire's Sealant, I would think it would have been made to leave the surface with nothing behind, as one would think the sealant needs a totally clean surface for 100% bonding. This is why I choose to use this over the P21S paint cleaner, as that is also a great product, but it does have clay in it and I would think that clay is not optimal for sealant bonding. Whatever is in it, I'm assuming it's compatible with the BFWD sealant. Thanks for reading... Next up: BFWD.
I'm a recent convert to Black Fire products, currently I've got BFWD, BF Crystal Seal which flashes in 45 minutes, awesome! as well as the BF total eclipse tire gel, that too is another great product, so for me, BF is batting 1000!
You'll need no larger than a dime size amount of BFWD per section or panel of your ride, make sure your applicator pad is sprayed with QD to make spreading of the product that much easier, just a tip I'd like to pass along.
Hope to see some overall pics of your ride when your all done:props:
...not done yet... I "cleaned" the paint (removed old LSP) and applied 3 back to back coats of BFWD. Now I'm waiting the 12 hours for it to cure, before I apply another coat, then I'll probably apply one more. After that, it's getting topped with Zymol Glasur or Fuzion. So, I don't want to show the completed pics until its complete. The BFWD went on super easy and thin. I used a P21S applicator. These applicators are great, as there is only a small amount of open cell foam to soak up product. This makes you get a lot of product on the surface, not stuck in the applicator. Also, they are a lot easier to clean for this reason.
After the applicator was primed it only took a very small amount of BFWD to do each panel. Only this much:
3 coats of BFWD only took about 3/4 of an ounce of product, thats about 7.5 mls, or half a tablespoonful per coat! This stuff goes on thin and goes along way. I let sections cure for well over an hour and removal of the product was very easy. The key is to apply it thin. I have been using PowerLock for a few year now, as 1 bottle of any sealant lasts me a long time. So far I'm liking BFWD better than Powerlock. The consistancy of Blackfire is runnier and it seems to spread better. I can comment on beading or longevity yet, but it's sure giving a great look. Here are some reflection pics from in my garage:
I decided to apply it by hand because i think you use less product, as there is much less pad to prime. Also, I think it's easier to work around the cracks and corners by hand and do a more precision job. However, if I was doing this for a living I probably would be using a machine.
I'm glad you liked both the items. I have to say I think we both came out great on that trade.
