Blackfire SRC Polishes Remove Swirls & Water Spots w/Flex XC3401
Nick McKees37
McKee's 37 Product Support
For whatever reason my friends, family, and co-workers are under the impression that I'm some avid automotive enthusiast who likes to test out new products and polish vehicles at every chance I get. Well, it's kind of true. Maybe it's because I'm always snagging the latest issue of Motortrend or Car And Driver from Max. It could also be that every time a new product comes out, I'm always the one grabbing for it first. Working at Autogeek gives me the opportunity to test new products AND write about them. When the Blackfire line was brought aboard, I didn't waste any time testing each and every product available.
Taking care of a black vehicle is not considered a hobby, it's considered a part time job. What's even better is buying a used black vehicle that hasn't been properly maintained in quite some time. Meghan just recently picked up a slightly used but swirled out black Ford Expedition. It has been my testing grounds for new products lately, and the other day was no different when I put the Flex XC3401 to work along with the Blackfire SRC Compound and SRC Finishing Polish.
I don't even think I have to elaborate on the condition of this vehicle. Take a peek below.
As much as I enjoy using my trusty Porter Cable 7424xp for its ease of use and dependability, I decided to grab the smooth-as-butter, tough as nails, lean mean paint correction machine known as the Flex XC3401. No exaggeration, it's that good. If you've ever plugged one in, let alone used one, you know exactly what I'm talking about.
I started off with the Blackfire SRC Compound. The pad of choice was a 6.5" Lake Country CCS Orange Light Cutting pad. Whenever I'm performing any type of correction work, I often grab this type of pad because of the CCS (closed cell structure) pockets found on the pads. These are pockets of closed foam, where products are less apt to soak into the foam. This reduces product waste and also allows the pad to run cooler.
I started off by priming the pad and then applying four dime sized drops of product.
The compound was spread out first at a lower speed and then I cranked up the Flex XC3401 to speed 6 and locked it in place with the trigger lock. It's similar to setting the cruise control on a Bentley Continental GT, meaning it's smooth sailing from here on out.
What really surprised me was how long of a working time Blackfire SRC Compound has. For a compound, there was virtually no dusting either.
To ensure desired results, meaning flawless butter smooth paint, it's critical to clean your pad often. I use the Foam Pad Conditioning Brush because it's easy to use, comfortable to hold, and with the stiff nylon bristles, will effectively break up caked on compound and polish residue.
Ready for round two!
Can you tell which side has been polished using Blackfire SRC Compound? If not, you need to adjust the settings on your computer monitor or get your eyes checked.
After wiping off the Blackfire SRC Compound and admiring my work (OK, credit goes to the Flex), I proceeded to step two with the Blackfire SRC Finishing Polish. Because the SRC Compound finished so nicely, I used a Lake Country 6.5" Gray Finishing pad with the SRC Finishing Polish just to amp up the gloss and further refine the surface. The Flex was set to speed 4 for this step.
After several section passes the polish starts to turn translucent as it breaks down.
Looks good to me!
Just a quick reminder of how bad the paint was when I started polishing. Left side hasn't been polished, right side has been polished.
Shortly after polishing the right side of the hood with the Blackfire SRC Compound and SRC Finishing Polish, it was time to apply the Blackfire Wet Diamond All Finish Paint Protection. I wasn't going to do all of the work myself, so I let Meghan apply the Wet Diamond sealant.
Blackfire Wet Diamond All Finish Paint Protection goes on extremely thin and for best results, let it dry to a haze before removing it.
After the sealant dried to a haze, it was buffed off using a super soft microfiber towel. When applied correctly, Blackfire Wet Diamond All Finish Paint Protection removes with just the weight of the towel. This isn't a sealant that fights you. It wants to be removed so it can reveal the shimmering wet shine that it's known for.
But I wasn't going to stop there. I had not experienced the Blackfire Wet-Ice Over Fire shine, so after the sealant cured for a couple hours a thin, even coat of the Blackfire Midnight Sun Carnauba Paste Wax was applied.
After removing the Blackfire Midnight Sun Carnauba Paste Wax, I was instantly greated with a deep, wet shine that is instantly recognized as being a Wet-Ice Over Fire shine.
I always enjoy testing out new products, especially polishes and compounds because you really see a drastic before and after difference once completed. The Blackfire SRC Compound and SRC Finishing Polish are very user friendly and when used in conjunction with the Flex XC3401, they have the power to cut through unsightly swirls and water spots leaving a flawless finish behind. Not only is the paint corrected on Meghan's Expedition, but it's also protected with help of the Wet Diamond sealant and Midnight Sun wax.
Don't just turn heads, create whiplash!
Blackfire Car Care Products
Nick, great reveiw again. Just amazing how a swirled up mess can be corrected with the right method and products.
Tom
In the wet diamond application photos you have some very pretty hands Nick!:xyxthumbs:
Reading is your friend. ;)
:props:
Ack, a ring on the finger while doing corrective work?! How could you? ;)
Nick,the Ford looks great.Good Job:xyxthumbs:
The only issue I would have,being a proffesional detailer is these light shots:
I would of liked for the light reflection to be more centered to truely see the comparision of the product capibilities.
There is no doubt that this is the money shot:
But I just would of hoped to see the full comparision ;)
Wow. I bet Meghan had to buy drinks after work for that job. Great turn around.
Just courious as to why you didn't use the PC to apply the Blackfire Wet Diamond All Finish Paint Protection?
thanks in advance
Some products, when used properly with the right tool, simply work great. If you'd like to do your own comparison, I would be more than happy to include a sample of each product with your next order. Just give me a ring. :xyxthumbs:
thanks in advance
For the sake of trying something different. :props:
Sounds good Nick,Thank You.:xyxthumbs:
Great, just what I needed to see! LOL, I don't have enough products in the garage! ;) Man, what a nice difference! Thanks for a great write up. I won't hesitate to try that product line after seeing results like this. I love the FLEX also and prefer the CCS 6.5" pads. Beautiful job. Have a good weekend.
You can never have too many products, and I can tell you that you will not be disappointed with any Blackfire product. :props:
Did Meghan trade off the 300?
I believe she picked up the Expedition to tow her boat...:cruisin:
have you compared these 2 with the other popular combos(105/205, wolfgang twins etc......)?
Nick,
I have a black van I'd like to try this on. It looks like I need the following:
  • BLACKFIRE Duo
  • Blackfire Wet Diamond All Finish Paint Protection
  • BLACKFIRE Midnight Sun Ivory Carnauba Paste
Is there a kit for this?
They're all great polishes with unique characteristics, maybe I'll do a comparison some time soon. The Expedition still has plenty of panels that need to be polished. :props:
Nick,
  • BLACKFIRE Duo
We sure do! You can order the Blackfire Duo plus the Wet-Fire Over Ice Kit. The Blackfire line is still growing so I would expect to see polisher kits available soon. :buffing:
